Fan stopped working
Old Aug 8, 2021 | 04:14 PM
wherlehy's Avatar
Angry Fan stopped working
Hello Experts,
Once again my Vent/ AC fan won't turn on. Is the only fuse to the fan on the fuse box?
I thought I remember there maybe a fuse under the hood with the AC that could of blown, but even when I turn on the vent fan (no AC) positions 1, 2 or 3, it will not come on.
Kind Regards,
Bill
Old Aug 8, 2021 | 04:36 PM
Sugar Bear's Avatar
The fuse under the hood is for high speed only.
Good luck!!!
Old Aug 8, 2021 | 04:37 PM
wherlehy's Avatar
Where is it located if I can ask?
Old Aug 8, 2021 | 05:45 PM
Sugar Bear's Avatar
What year and model are you working on?
Old Aug 9, 2021 | 07:23 AM
wherlehy's Avatar
Sorry... 1970
Old Aug 9, 2021 | 12:57 PM
wherlehy's Avatar
Any advise experts?
Old Aug 9, 2021 | 01:29 PM
rocketraider's Avatar
Oldsdruid
You've checked the HEATER AC fuse in the fuse block? If it's blown nothing on HVAC will work.
Past that there's a master switch on the control head.
Old Aug 9, 2021 | 01:38 PM
Sorry... 1970
Is there a Model associated w/ the year? Magic 8 ball isn't working.
Old Aug 9, 2021 | 01:54 PM
wherlehy's Avatar
Hello,
where is "Past that there's a master switch on the control head."
Regards,
Bill
Old Aug 9, 2021 | 02:50 PM
Oldsdruid
It's located behind the dash on the heat and AC control panel's slide bar. Turns the blower on in any position but OFF.
Before digging into it that far, unplug the purple wire from the blower motor at right rear of engine compartment underhood and clean both terminal and plug. Then run a jumper wire from blower motor terminal to the battery positive terminal. This will tell you if the blower motor is good. If it starts and runs, and you know the HEAT AC fuse is good, problem is between fuse block and blower motor. If not, and motor has a verified good ground, motor is bad. Replace it.
Will not hurt to unplug the blower resistor connector underhood and clean those terminals. Maybe even pull the resistor out and check its condition.
Old Aug 9, 2021 | 03:02 PM
A-Body vehicles. Anyone's guess what Model you have. I'm not going to ask again.
https://classicoldsmobile.com/forums...-blower-93740/
Koda
Dec 5, 2020 02:49 PM
wherlehy
Sep 29, 2020 11:46 AM
Herv Purcell
Jul 21, 2015 09:40 AM
patrickoglesby
Ninety-Eight
Jun 30, 2015 05:07 PM
js_specials
Aug 19, 2006 09:53 AM
