Everything is dead , but the battery
Old July 30th, 2010, 10:42 AM
cbogartjr's Avatar
Hi, I drove my 67 442 last night and it ran fine. I stopped and shut the car off a few times and then restarted it. All went well. I drove in the dark, so I had my headlights on. All seemed ok. I pulled it in the garage and shut it off after I turned off the headlights. This morning I went to start the car and ...nothing. Thought I left the interior light on...nope. I then put the battery on my charger and it checked out ok. I also check the battery voltage with a volt/ohm meter and it checked out ok. I then checked the fusable link...the continuity was there through the link. I check the wires for burns or discoloration and couldn't find any. I checked all the fuses in the fuse box. They check out ok. I get power to the relay box on the drivers fender well. It seemed fine. I am not sure where to go from here. I have an extra voltage regulator I could replace the one in the car with that. Suggestions on my next step? Thanks for your help....
cbogartjr is offline
Old July 30th, 2010, 11:04 AM
jeffreyalman's Avatar
do you have lights, horn? tap the starter and tap the starter solenoid, try again. check both batt cables at both ends of each, should be one of the above.
jeffreyalman is offline
Old July 30th, 2010, 11:10 AM
svnt442's Avatar
Do you get the idiot lights come on when you turn the key to the on position? If so it's leaning towards the neutral safety switch.
svnt442 is offline
Old July 30th, 2010, 11:28 AM
ah yes - and a test would be to hold the key in start position while slowly moving the gear shift and see if that wakes it up
Old July 30th, 2010, 11:47 AM
Past Administrator
Oldsguy's Avatar
Check your ground cables and straps as well. A DC circuit needs a complete loop to operate.
Oldsguy is offline
Old July 30th, 2010, 12:02 PM
Lady72nRob71's Avatar
EVERYTHING is dead? If so, check the battery cables. They might look okay, but where the wire part meets the connector might have failed. My bike did that once...
Lady72nRob71 is offline
Old July 30th, 2010, 01:08 PM
cbogartjr's Avatar
OK..did some more testing. Only the horn works, very strong!!...no interior lights, headlights, turn signals, nothing.. I did the test of putting the key in the start position and slowly running through the gears...nothing changed. I then took a very good set of jumper cables and 1) attached them to the neg side of the battery and grounded them to the frame...no change...2) I took the ground off and attached the jumper to the positive side of the battery and attached it to the terminal on the fender well (where the positive battery cable connects)...no change. I am stumped here...I will take a look at the cable that hooks to the firewall and make sure it is snapped in. Come to think of it, I had a problem there once before with the left turn signal. The plug wasn't all the way snapped in...Any other thoughts????? Thanks to all for your help...
Old July 30th, 2010, 01:13 PM
if the horn works and nothing else then that means something - I forget what it means though, but someone will know shortly - all batt cables are good and tight both cables both ends? and ground straps as mentioned?
Old July 30th, 2010, 01:35 PM
citcapp's Avatar
Had a similar problem with my 57 a few weeks ago. I had in fact left the key in the ACC position and did not notice it (you can do that and take the key out with a 57) Tried to start a week later, nothing, horn worked headlight looked OK, Put a volt meter on the battery 12.5 volts. I was stumped at first then I jumped it with my wife's car and it started right up. I then put my battery on my battery tester and yes it showed 12.5 volts but not under load when I checked the battery again with the lights on it went to 9 volts, not enough to engage the starter. I let the battery charge at 15 amps for a couple of hours, car started right up and everything is fine. Moral of the story is the battery needs to be tested under load.
citcapp is offline
Old July 30th, 2010, 06:02 PM
marinus_'s Avatar
I had a similar problem with my Starfire when I got it nothing worked. I found a problem with a circuit breaker located on the firewall. On my car the horn was connected directly to the battery through the relay located on the inner fender so it would work.
Just a thought.
Rene
marinus_ is offline
Old July 30th, 2010, 06:09 PM
cbogartjr's Avatar
Hi, the voltage reading is 13.2 volts. Charger shows battery is fully charged. Tried a second charger and it also shows battery is fully charged. I did try jumping it from another car to no avail...nothing. I checked the plug going into the firewall and all seems fine and well connected. My battery cables are pretty new (about a year). Horn still works fine. I rechecked all grounds and they seem to be fine. I will keep on looking.
Old July 30th, 2010, 06:21 PM
marinus_'s Avatar
Do you have a multimeter to check for power at the fusebox? If there is no power there, then there might be a fuseable link somewhere between the battery and the fuse box.
marinus_ is offline
Old July 30th, 2010, 10:46 PM
Junior Member
88 coupe's Avatar
Originally Posted by cbogartjr
........ Only the horn works ........
Loose and/or dirty bulkhead connectors. Easy to verify by tapping/jiggling them.
Common occurance in '64 A Bodies when they were new. Not common in '65. Unusual in '66 and newer.
Norm
88 coupe is offline
Old July 31st, 2010, 03:38 AM
cbogartjr's Avatar
Thanks guys, I will check the fuse block. I did check the bulkhead/firewall connectors, as I had a problem with a turn signal and found a bad connection. I will check them again....I am trying to find the circuit breaker Marinus talked about. Where exactly is it? As I get into this, I find someone has screwed around with the wiring somewhat. I did find the fusable link..it has continuity. Next to the fusable link is a red wire with a use holder and a fuse. I did check the fuse and for continuity and both seemed ok, but why the fuse? I'll dig more into the wiring diagram. I find the black wire that would appear to run to the circuit breaker, but loose the wire behind the power brake vacume canister. I think I will need to go under the car to find the circuit breaker.
Old July 31st, 2010, 07:10 PM
marinus_'s Avatar
On my car the circuit breaker was located to the left of the brake, master cylinder and mounted on the firewall.
marinus_ is offline
Old August 1st, 2010, 05:32 AM
cbogartjr's Avatar
Thanks to all, especially Norm. I metered everything. I couldn't find the circuit breaker though. Maybe that is why someone put a fuse in the line. I worked backwards from the fuse box as I had power at the connection box on the fenderwell. Anyhow, I removed the plugs from the firewall/bulkhead (per Norm's {88-Coupe} suggestion) just to see if there was anything wrong there. One plug came off pretty easily. Cleaned the pins the best I could. Made sure they were straight and reconnected to the bulkhead and.... WALAH...back in business!!! This is the second time I have have an electrical problem in this area. Thank you all for your help and guidance. I really appreciate it and this site.....Carl
Old August 1st, 2010, 09:08 AM
citcapp's Avatar
Glad you were able to solve your problem. That is what this site is all about
citcapp is offline
59Olds98
December 25th, 2013 08:20 AM
Jetstar 88
June 28th, 2013 08:34 AM
jaymann
July 10th, 2010 06:37 AM
w-30dreamin
January 9th, 2010 03:19 PM
JSGD1966
August 27th, 2008 07:40 AM
Quick Reply: Everything is dead , but the battery
