engine ground wire location
Old Oct 22, 2012 | 10:59 AM
pbarney's Avatar
I have a 67 cutlass s
The 330 has a ground wire wire (just the end terminal) attached to the bottom of the power steering braket. I would like to conect a new ground wire. Where is the proper place to conect the other end?
Thanks for all the help everyone!
Old Feb 8, 2013 | 07:00 PM
FAZ442's Avatar
I have mine to the first bolt on my headers on the block.. dont know if its correct or not.
Old Feb 10, 2013 | 12:47 PM
pbarney's Avatar
Thanks for the reply. I have a motor ground conection at the power steering pump-where on the frame or body close by is the proper location for the other end of this ground cable?
Old Feb 10, 2013 | 12:59 PM
The heavy ground cable from the negative battery terminal goes to the engine block in an area adjacent to where the battery sits - this is probably the site of the terminal you mentioned.
The engine is grounded to the car by a woven ground strap (sometimes 2 of them) about ½" wide and 6" long, that goes from one of the blind bolt holes on the back of a head to the firewall.
377rick
Jun 16, 2015 08:16 AM
JPMDaddy
Oct 20, 2013 08:21 AM
Tedd Thompson
Jul 25, 2012 02:06 PM
70-442-455
Oct 4, 2008 09:06 AM
Redog
Mar 11, 2008 10:37 AM
