engine dies
I had the same issue when I wired in a Ford Starter solenoid. Turned out I had wired the ignition to the wrong side of the solenoid.
what have you done to get the car running? did you do any wiring repairs?
well when i took body off, i took complete harness out of car ,tested what i could, fixed a couple of cracked wires ,and hoped for the best,had to take fuse box apart ,there had been a water leak, so it was pretty nasty,also this was two years ago. with my memory ,its like i never did it,any way thanks for the help , will go out today and just look to see if something is out of place, will
Kidcutty
July 13th, 2010 05:06 PM
