Engine dies on full tank of gas????
Old Nov 21, 2011 | 03:40 PM
sicky olds's Avatar
NôôB
Yup you read right. Seems to me the engine either is flooding itself or not getting enough. Seems to be after i fill it up she will sputter out. When i hit the gas she will come to life for a split second then die out again.... any ideas
Its on the Rallye btw
Old Nov 21, 2011 | 04:52 PM
AZ455's Avatar
1974 DELTA 88
Are you trying to squeeze every last drop possible into the tank? Maybe the charcoal canister became saturated with fuel from overfilling the tank. Does everything go back to normal after you've used up some gas, or is this the fist time it's ever happened?
Old Nov 22, 2011 | 10:29 AM
jackedolds's Avatar
Not sure of the set-up, but if the car has an evaporative emission system (charcoal canister) the fuel tank should be vented. There are two main ways to accomplish this - a vent/vacuum breaker fuel cap (not sealed) or a tank vent that typically have a hose running up to the air cleaner. leave fuel cap loose and see if problem persists. If so - look into tank vent, if not - look elsewhere.
Old Nov 22, 2011 | 05:11 PM
sicky olds's Avatar
NôôB
No dont overflow the tank, i stop when the pump auto stops . The funny thing is after i let it sit for a couple hours, she starts right up and i drive her just fine
and i dont think it has an emissions system on it
Old Nov 23, 2011 | 08:56 AM
jackedolds's Avatar
In 1970 I believe that some cars had the canister and some did not (I suspect california cars did and Federal did not) - if the emission sticker is still in place underhood it will tell you. Loosening the fuel cap to see if the problem changes is worth the minute it will take to rule one more thing out. A bit of advice from someone who once had a brainfart about tightening the gas cap......don't go driving wild while it is loose :-)
jaunty75
Jun 4, 2015 06:27 AM
Joffroi
Mar 21, 2014 06:23 PM
Texas442
Jan 30, 2012 05:36 PM
truthautomatic
Mar 6, 2010 07:03 AM
Deputy442
Apr 14, 2009 07:42 PM
