Electronic ignition recommendations
Hi all,
Looking to upgrade the ignition/points on my '69 Cutlass S with a 350 any recommendations? Looking at a Pertronics 1181LS and matching coil right now.
Thanks!
Thanks!
MSD 8529 - a drop in 3-wire electronic ignition distributor. You can install either an HEI-wire style cap or standard (points-type) style cap on it. a good coil to go with it is the MSD Blaster 2 - this is the current setup on my '72 350 and it's been flawless for almost 3 years now
Opinions vary on Pertronix but I personally wouldn't touch one again even for free.
I found this on summit with just a one wire to IGN https://www.speedwaymotors.com/Oldsm...tor,10180.html for $150 just worried about the height don't want to have to modify air cleaner etc
Just buy an OE HEI distributor from the auto parts store. It will have a lifetime warranty and is the exact same unit as the Summit/Jegs/DUI/Accel etc. distributors.
https://www.oreillyauto.com/detail/b.../cutlass?pos=0
Right you are Eric. I suppose it's a case of pick your poison. Any distributor can be re-curved with different mechanical advance weights/springs and vacuum advance dashpots. The OP just needs to decide if he wants to spend more on a performance distributor.
He did say he has a 69, therefore the curve on the parts store unit will be off. Those distributers are replacements for late 70's early 80's smoggers. The vacuum advance is like 15 to 17 degrees. He'll have to add and adjustable vacuum advance kit for rate, limiter for travel and possibly springs.
That's why I said Progressive Ignitions and be done. Do it once, do it right and have infinite adjustability in your timing, from your phone via bluetooth connection. At this point its a no brainer.
Any electronic distributor replacement suggests you should carry onboard circuitry replacements. Points fail slowly, electronics can die in a second and leave you dead right there until replaced.
I don’t regret going to HEI but have had 2 failures. One bad pole piece on OE, one bad Ford EEC pickup on my Mallory. Because of this I keep a whole spare HEI (can’t remember if OE or Tong Yang anymore) in the trunk and quickly swapped it out on those 2 occasions, back in transit in 10 minutes.
I've had really good luck with MSD 8529, I'll probably be listing it for sale since my 463 is out of commission.
Avoid Cheap Chinesium, oil find the way through the shaft and floods everything inside the cap.
