Electrical Troubleshooting
Old May 27, 2016 | 10:04 AM
Octania's Avatar
Some Other Brand [71 Challenger] car, troubleshooting fun:
Fuel Gage
Assumeframe to batt (-) is ok, all else works.
At tank sending unit terminal 90Ω to frame
Gnd strap across rubber line intact
0Ω tank body to frame.
Wire from car shows ~5V DC, correctfor 71 Dodge’s gages' V. Reg’r.
At dash
VReg shows 12V in, ~5V out to all threegages, pulsed or AC says the consultant
Gages read ~13-15 Ω each one, no wiresattached
Grounding the tank wire makes Fuelgage read full
I surmise this means the sending unit (new, Chinese?) is bad.
TEMP GAGE
similar no reading
grounding wire at engine makes gage peg the needle, so gage and wiring intact.
Probably a idiot lite sender- 1/8 NPT unit.
infinite ohms at room temp, open circuit across the sender.
TACH
THREE wires on coil negative- WTH?
Two are gray
tach should be gray/red
Sending 12V in at dash end gets nothing at coil end. ???
consult manual.
Gray wire should be here at firewall.... EMPTY NEST, no wire there at all.
Aye, aye, aye.
Easy enough fix.
PS they use a BLACK wire for POWER, from alternator, to gages, etc.
Idiocy, that.
Old May 27, 2016 | 10:37 AM
Mopars work differently than our Olds's. Scroll down to the middle of the link page.
http://moparfins.com/Repairs/Fuel_Ga...uge_Repair.htm
Old May 27, 2016 | 03:27 PM
m371961's Avatar
I worked on Fords and Mopars from 60s to 80s. Olds certainly are different and were /are a learning gig for me. Worked on Internationals also. ALL their wires were black and numbered.
Old May 27, 2016 | 03:36 PM
Originally Posted by m371961
...Worked on Internationals also. ALL their wires were black and numbered.
Worked on airplanes, all the wires were white and numbered.
Old May 28, 2016 | 10:30 AM
Octania's Avatar
OK, but, to me, using black for a power wire in automotive applications is just not right.
thanks for the link to the gages issue, will ck that now. I believe we have all three problems nailed, as soon as parts arrive.
Old May 28, 2016 | 03:19 PM
Electrons are color blind, they simply don't care about wire color.
Old May 30, 2016 | 02:50 AM
Levellord's Avatar
The PO of my car seemed to own just black wires. He wired everything black, regardless of plus, gnd or signal. Already spended me a lot of "fun" :-\
Old May 30, 2016 | 05:20 AM
The advantage of them using black wire or any other color for that matter is that you can easily trace out non stock mods. I use Red wire for everything.
Old May 30, 2016 | 07:58 AM
redoldsman's Avatar
Proud Viet Nam Veteran
I always use red for power and black for ground. The others are usually yellow or blue because that is what I have on my bench.
Boldsmobile
Jan 22, 2011 01:31 PM
PmL69
Aug 22, 2009 05:39 PM
bearls
Dec 5, 2006 04:50 AM
bearls
Dec 2, 2006 07:06 PM
Fuzzbeaner
Jul 9, 2006 06:26 PM
