AM radio
Old May 28, 2016 | 02:33 PM
tschie's Avatar
AM radio
Could someone please tell me how to wirer up the speaker on a 1966 oldsmobile 442. Ive got power to the radio. theres only one speaker mounted in the dash (orginal) Looking at the back bottom right hand corner theres a connector where you hook the yellow feed wire and 2 wires i think go to the speaker.ive hooked them up to the speaker but no sound .Ive plug in the antenna to the radio. Then theres a blue wire that i dont have a clue where it goes. Any helpwill be Great.
Thanks Tom
Old May 28, 2016 | 02:58 PM
rcorrigan5's Avatar
Randy C.
If it's anything like a '68, there should be a yellow wire (12V), a blue wire and a black wire, all joining into the same connecter that goes into the back of the radio. The blue wire is your feed to the front speaker and the black wire is a ground that returns from your front speaker to the radio.
If you have another blue wire with a connector on the end besides what I just mentioned, that would be for a rear speaker and your radio should have a fader dial on the right side that adjusts sound from front to rear.
Randy C.
Old May 28, 2016 | 03:17 PM
tschie's Avatar
Thank you, Im still confused on the blsck wire returning from the speaker. The speaker has 2 connection points. and i think the blue wire is the shunt wire where does hook up.
Tom
Old May 30, 2016 | 03:19 PM
radioburningchrome's Avatar
The speaker will have 2 connection points. The blue wire is the (+) positive connection. The black wire is ground , aka shunt.
Connect the blue wire to the radio and the black wire can be wrapped around one of the speaker mounting studs.
The black wire might not be necessary as the speaker might get a ground from the metal base.
Try connecting the black wire to ground and try not connecting it.
dnmfranco
Jul 2, 2014 05:10 PM
dancutlass
Oct 2, 2012 02:49 AM
sx455raidercelticfan
Jul 29, 2010 07:44 PM
TIREGUY
Dec 16, 2006 04:10 PM
<Norm Witte>
Jan 12, 2006 02:46 PM
