Electrical shortage
Old Aug 25, 2017 | 08:20 AM
Dibabyboyde7's Avatar
Electrical shortage
on my 63 olds 98 the horn wiper and fan does not work. But it work if it wired straight. What does this sounds like
Old Aug 25, 2017 | 08:34 AM
First, did you check your fuses? If they are all good then it's time to use your multi-meter.
Check for 12V at your horn button, wiper switch and fan switch. If you read 12V then there is a problem with the circuit after the button/switch. If you don't have 12V then there's a problem before the button/switch.
Old Aug 25, 2017 | 08:39 AM
You won't find power at the horn button. The button switches the GROUND, not the power.
To the OP:
What exactly did you hot wire to get these items to work? This is pretty basic stuff. If the accessory is working, either the power source or the switch is bad, or the wiring between them is bad. Trace it back with a test light until you find the problem.
Old Aug 25, 2017 | 08:42 AM
Oops...
jf857
Apr 28, 2006 07:24 AM
BOB W M
Apr 7, 2006 06:30 PM
PetChemMan
Dec 15, 2005 04:15 PM
86in
Feb 9, 2005 09:49 AM
NV WIDOW
Sep 1, 2004 04:34 AM
