Electrical issue in 68 442
Old Aug 12, 2009 | 12:21 PM
4speedBench's Avatar
Angry Electrical issue in 68 442
Could use some thoughts here...
Recently while tuning the car the timing light lead accidently layed against the hot exhaust manifold causing a loud "pop" and the car backfired through carb and shut off. However, it re-started and everything seemed fine. We drove it, gauges seemed fine as well as lights, etc. I thought I had dodged a big one.
Well, the car was driven again a week later and I thought I noticed the gas gauge was slow to respond, but it eventually did and accurately.
Today, it started fine, I was going down my driveway and it died. No clicking with the starter. I started checking things and noted my headlights no longer went on, but parking did?? the dome light works, but goes off if you put on the lights. I know 68 does not have a fuseable link. Did not see any fuses shot. I'm wondering if voltage regulator or the main wiring harness may be the culprits. I realize it could be many places but thought I'd get some input as to where you would start. I don't have a light meter, but do have a test light.
Thanks!
Old Aug 12, 2009 | 01:28 PM
slowolds's Avatar
Loose Radical
Two quick checks that don't require special tools:
pull a plug out and see it there is spark to the plug when you crank it
if a '68 has a yellow and purple pair of wires from the starter you can separate it and short the purple to the horn relay post (where the positive battery connection is) and see if the starter engages
Old Aug 12, 2009 | 01:35 PM
68Tom's Avatar
When my voltage regulator went, my battery got unbelievably hot and almost exploded. Not sure if your battery is getting warmer than usual, but might want to check.
Old Aug 12, 2009 | 02:07 PM
Nilsson's Avatar
68 does have a fusible link at least mine does.
Old Aug 12, 2009 | 07:44 PM
Thanks guys. I'm beginning to think it may be in the Forward light harness as my Shop Manual shows that harness as supporting the headlights as well as " regulator functions".
Man, I was all set to hit Alliance this weekend until this...
I don't see any Fuseable link on mine. If you have a photo of where yours is maybe I'm just missing it???
Old Aug 13, 2009 | 04:36 AM
Nilsson's Avatar
Pictures of the fusible link located at the door buzzer relay on driver side inner fender well. Also see picture of the ground wire for the core support these can burn and fray and will cause the headlights to not operate. This would not cause a no start condition though.
kona0197
Jun 11, 2011 05:38 PM
ChefDeadpool
Dec 26, 2010 07:55 AM
jpaulwhite
Aug 21, 2010 06:08 PM
dhartley72
Mar 15, 2010 08:12 AM
blueolds68
Feb 9, 2010 06:55 AM
