Electric Choke '71 Cutlass
Old Aug 13, 2022 | 08:46 AM
Falkon's Avatar
Engine is a 350 w/ 4 bbl, & electric choke. Where should the choke get 12 volt ignition feed? Prior owner recently added HEI ignition. There are now 2 what look like white wires connected to a red wire leading into the distributer coil. If they didn't change the harness, it looks like it could be running through a resister wire. Is this possible? HEI should have 12 volts. Car runs perfectly. The choke is currently wired to a tap into the washer circuit yellow wire. This works BUT is an Ign. Accy. fed wire along w/ the radio. Works as long as you don't use Accy. w/ a cold engine. I have 2 wiring diagrams (one is from the factory manual) & neither show the choke circuit.
Old Aug 13, 2022 | 08:53 AM
On my phone limited abilities. Search username Joe Padavano think it’s in electrical forum. Great diagram/discussion for electric choke wiring.
Old Aug 13, 2022 | 08:59 AM
Here you go:
https://classicoldsmobile.com/forums...-wiring-31892/
Old Aug 13, 2022 | 02:15 PM
Falkon's Avatar
Thank you, a good solution. Conversly I just was looking at a wiring diagram & my car. I have an unused/disconnected at the trans, TCS switch, at the right front of the engine. 2 green wires w/ a resister across the terminals. One is Ign.+, & thge other goes to the trans switch. My trans guy said it's disconnected down there. Car's vacuum advance is connected directly to manifold vacuum. Could one not use that green Ign. wire to power the choke also? It would be very simple. About 3" from the choke.
Old Aug 13, 2022 | 02:26 PM
rocketraider's Avatar
Oldsdruid
As long as it's SWITCHED 12v power you're good. You want it powered in RUN only, not when the ignition switch is in ACC.
Joe's design powered from the alternator thru a 3 terminal oil pressure switch is the best way I've seen to do it.
Old Aug 13, 2022 | 02:34 PM
Falkon's Avatar
THANK YOU very much. Sorry for all the confusing questions. I just bought the car & am sorting a few things out. My first time w/ electric choke.
block727
Jun 11, 2021 03:07 PM
Chuck Cole
Aug 24, 2020 11:49 AM
Chuck Cole
Jul 9, 2019 09:38 PM
projectheaven
Aug 27, 2011 04:35 PM
woodie582
Nov 7, 2008 01:07 PM
