Electric Choke
Thanks Joe. I guess I will pick one of those up this evening. I haven't bought a replacement for my oil pressure switch yet anyways. I assume that this goes behind the water pump in the normal place for the oil pressure switch?
I also did some research on wiring my HEI ignition. I decided to splice a wire into my fuse box at the "IGN" terminal. This is the pink wire that goes to all of the lamps in the dash and to the firewall where it changes to the "resistance" wire. I removed the yellow wire that previously ran from the starter to the coil.
I went to O'Reillys last night and bought one of the oil pressure switches Joe mentioned. I found out that the threads on the switch were 1/4" and the threads in the block are 1/8". I went to the hardware store and got an adapter. I plan on installing it this evening. Thanks for the tip Joe.
