dumb ?. won,t start
dumb ?. won,t start
hi, car started 2 months ago no problem,65 starfire, any way when i go to start the volt meter goes to 12 volts ,but when turn to crank engine it goes back to 0, and starter does not click or nothing , cleaned battery terminals and where the junction box is with the horn relay. cleaned the ground on the block that goes from the battery, i must be losing my mind,use to be able to figure stuff like this right a way, any way can any body help me on this , thanks . will.
won,t start.
hi, thanks for all the replies,i did check battery ,its good,turned on head lights .then tried to crank engine they did not dim at all. the only clicking i hear is the horn relay i think.also if i turned the head lights on ,and watch the volt meter, it drops very little.took console off ,and i don,t see any thing wrong. but who knows,like i said started perfect 2 months or so ago. now nothing ,also went under car and tightened the nut on the solinoid,to make sure good conection , also almost all this electrical stuff is new , to ,ok ,thanks again for all the help.will.
all set
put a jumper on the nuetral saftey switch, back up lights worked with jumper , and when i put jumper in the other plug ,engine turned over , so guess i need a new switch, so i thank all for the help, it really helps with the extra suggestions, gets ya thinking better, will.
