Drained Battery
Old Jun 1, 2012 | 02:48 PM
Magna86's Avatar
Drained Battery (new ? culprit found)
Came out to start the Olds yesterday and bam dead battery. The battery is brand new and charged backup when I stuck it in a charger. Now it had been 2 wks since I drove it. So thinking slow draw but no.idea where. I put me meter on it after driving her around a bit and with ignition off it sits at 12.11v. I checked to make sure.the center console switch was working properly and it was. All I have done to the car was hookup a tach used the wires from clock, a solid ground and tach signal wire at coil. Also hooked up gauge pod ran.power to.empty spot in fuse block, ran a ground and tapped into dash lights for gauge lights. Right now have it hooked up and will check voltage again later to see if drop. Any ideas would be.great on this gremlin.
Magna
Old Jun 1, 2012 | 03:47 PM
The tach needs to be powered on a keyed 12v. It's probably drawing your battery down.
Old Jun 1, 2012 | 03:52 PM
Magna86's Avatar
Hmm ill have to check to see if I used a keyed wire or not. Thanks
Old Jun 1, 2012 | 03:56 PM
The clock wire is not keyed. It is constant power.
Old Jun 1, 2012 | 04:12 PM
Rickman48's Avatar
X 2 - caught that right away!
Old Jun 1, 2012 | 04:39 PM
checkered past's Avatar
You can remove the neg. batt. cable and then by using a dvom in the ampmeter position connect one lead to the cable and the other to the post (in line with the circuit).... That will give you key off current draw....monitor the meter while removing fuses or previousley installed equipment and that should norrow down the culprit.
Old Jun 1, 2012 | 05:11 PM
Octania's Avatar
worst case, buy a Battery Buddy.. it disconnects the battery before it drains down too low. Kid's car buzzes at you as you leave as if the lites are on, even if they are not... therefore it gets ignored, and the battery got run down... Installed a BB... easy fix now, no need to call for a jump.
Old Jun 1, 2012 | 07:45 PM
Magna86's Avatar
Ok tapped into wire for gauges for tach. See if this fixes it. Now my ? is why would it draw since not powering? What's the difference from the clock being there running?
Old Jun 1, 2012 | 08:02 PM
Lady72nRob71's Avatar
Try the ammeter test as recommended already and post your findings. I know from experience 250mA will drain the battery in a week. It should be less than 20mA.
If you come up with a low reading, charge and disconnect the battery and let it sit for a week. If it will not start the car, the battery is crap. I have seen several new batteries that were bad like that, all after the prices almost doubled - go figure...
As for your tach, put the ammeter inline with its power source and see what it draws. The tach I have is powered from the constant 12V and never drains the battery in 2-3 weeks. Of course this is all dependent on how the particular tach is built - how the electronics work.
Old Jun 1, 2012 | 09:28 PM
jchavis44's Avatar
im having the same problem...new battery from autozone and next morning drained....i jump started it and it crunk right up so i just disconnect the batt until im ready to get in it again.. i used a test light and disconnect the neg and positive and during each one i removed the fuses and light never went off or flickered...im driving a 1965 delta 88 celebrity sedan...any idea's and also i haven't put anything new on the car, i bought it like that and currently fixing!
Old Jun 2, 2012 | 04:32 AM
joepenoso's Avatar
It's funny you should post this as I had the exact same problem. Replaced clock with an Autometer tach and received a drained battery. I was going to pull the tach and replace the red wire ( Live feed to the clock originally) find a keyed wire to hook in to. All this on my 71 442.
joepenoso
Old Jun 2, 2012 | 05:05 AM
Originally Posted by Magna86
... my ? is why would it draw since not powering? What's the difference from the clock being there running?
The tachometer generally has four wires:
  • One for the light
  • One for power
  • One for the sensor
  • One for ground
The tach will draw current through the power wire regardless of whether there is a signal on the sensor wire. The circuitry doesn't care whether there is a pulse there or not. It is using current while it waits for the next pulse.
The instructions for every tach out there are very clear that the red wire is connected to a switched ignition circuit, for example:
Why would you connect it differently?
Like the instructions above tell you to? Good idea.
I have absolutely no idea what this means.
Old Jun 2, 2012 | 05:20 AM
joepenoso's Avatar
Thumbs up
All right I am guilty . I used the clock red wire because it was there and easy to hook up. I *** sumed the draw would be negligable.........
Mea Culpa
joepenoso
Old Jun 2, 2012 | 05:21 AM
1970cs's Avatar
Lansing built
I am with Eric? You should leave the positive cable hooked up and remove negative only, clamp your test light to the neg post and connect the probe end to the negative cable or in series! Then pull fuses or unhook componets like alternator/generator one at a time to find which circuit it is.
Good luck
Pat
Old Jun 2, 2012 | 05:31 AM
As my father used to tell me when I was a kid:
"If all else fails, read the instructions."
The IGN tap on the fuse bock is a fine power source for a tach.
Old Jun 2, 2012 | 08:16 AM
joepenoso's Avatar
Question
The one under the dash?
joepenoso
Old Jun 2, 2012 | 08:46 AM
Yes.
Old Jun 2, 2012 | 08:50 AM
The one in the fuse block.
Old Jun 2, 2012 | 11:20 AM
joepenoso's Avatar
Red face
Can I get at it with explosives?
joepenoso
Old Jun 2, 2012 | 11:41 AM
joepenoso
LOL, thats one way! Not always my first choice, but it does rate in the top ten!
Old Jun 3, 2012 | 06:32 AM
joepenoso's Avatar
Thumbs up
Well I pulled the tach ....disconnected the red wire .....connected it to the underdash fuse box by stripping the plastic off the wire and wrapping it around the fuse before popping it back into the box. Another problem solved without explosives
joepenoso
Old Jun 3, 2012 | 07:32 AM
The IGN terminal it a port at the very front center bottom of the fuse block - right in plain sight.
Where the yellow wire is plugged in this picture...
Old Jun 3, 2012 | 09:18 AM
joepenoso's Avatar
Talking
I wrapped my wire around the guage fuse right beside it. I checked to make sure no power flowed unless the key turned the ignition on.
joepenoso
PS Thanks for the picture and interest in my problem. The battery was marginal and the slight tach draw was enough to push it over the edge.
Old Aug 20, 2012 | 12:07 AM
Magna86's Avatar
Ok now that I'm back on land I had to time to search out the answer to the drain. I had my buddy hold my meter connected inline while I went and pulled fuses. With the meter on ohms I was getting .650-.700 draw. I found some draw on the clk fuse but there was a draw after I pulled all the fuses. Then I realized the amp in the trunk was still hooked up. After I disconnected the inline fuse it was gone. I've had a car with a amp before but never had a draw problem. My buddy said something about wiring a a kill switch in that circuit to shut off the amp draw? Now with the clk fuse pulled it kills my interior lights and my stereo? I can't remember what the draw was with the doors closed but is there supposed to be one there on this circuit? If so what is it supposed to be or would be acceptable as to not killing the battery. (I drive the car usually once a week when I'm home sometimes more or less)
Magna
Old Aug 20, 2012 | 05:35 AM
1970cs's Avatar
Lansing built
ohms? I would have thought it would be set for volts or amps!
Pat
Old Aug 20, 2012 | 07:19 AM
There are a coulple of ways to power the amp, so that (1) it comes on with the key, and (2) it is not powered when the radio is off. Look at the schematic for the radio and amp, it will tell you how to hook it up correctly.
These are the 3 things that kill older car batteries, lighting, gauges and tach's, stereo equipment.
Old Aug 20, 2012 | 08:24 AM
Your amp is connected wrong. It shouldn't be drawing a measurable amount of current when off.
Recheck all of your connections and make sure that the turn-on wire for the amp is actually connected to the turn-on wire from the control unit, and not to a hot wire.
If it is connected correctly, then there's something wrong with it.
If you still want to use it as-is, then connect a relay in its power line, with a current rating greater than that of the fuse you are using, and trigger it off of the ACC circuit.
The CTSY ("Courtesy") circuit powers the interior lights, the clock, and the cigarette lighter(s). It should reflect the draw from those items. Several amps with a door open, a blip of ¼-½ and amp or so every few minutes when the clock winds itself, and a good 10-15 amps with the cigarette lighter pushed in.
You shouldn't have connected the stereo to it, as it is constantly on, and runs through an easily-blown fuse (any jiggling or problem with the cigarette lighter or its socket, or with an accessory plugged into it will blow the fuse).
It shouldn't have any draw with the doors closed, dome light switch off, map light switch off, lighter not pushed in, and clock not winding. If it does, there's a problem.
I just want to point out that these two sentences make no sense.
Ohms measure resistance.
Amps measure current.
Volts measure electrical potential diference.
By "connected inline," I assume you mean "connected in series." If this is the case, and you had your meter set to Ohms, then your meter would have either not read anything, or would have blown up, depending on how well it was designed.
The 0.650 - 0.700 reading you got would have been in Amps if you were measuring "draw" (current). It could not have been in Ohms, which measure resistance.
The correct procedure to check for a parasitic drain, as mentioned above, is to connect an ammeter in series with either the positive or negative battery terminal. You should start with the highest ammeter range (hopefully 10 Amps), and then adjust down if there isn't enough current to read at that range, so as not to burn the meter (or blow its fuse, as the one in there is never one you have in the toolbox).
An alternative is to check the resistance between both battery cables DISCONNECTED from the battery, but this may not be as accurate, as some electronic equipment might not pass current at the roughly 1.5 Volts that the ohmmeter puts out, but will pass current at the 12 Volts put out by the battery.
Old Aug 20, 2012 | 06:29 PM
Magna86's Avatar
See what happens when you are away from toys too long you lose your thinking! As far as the stereo system and its wiring the car came with it this way so not sure how they wired it but obviously have to check them out. All I know with the amp at this point is there is a hot wire run directly to the pos cable on the battery with an inline fuse. After work tonight will go look into this further and see what I find.
Old Aug 21, 2012 | 07:41 AM
The amp will have a main hotwire to the battery, most likely a 10ga fused. Then it will have a trigger wire from the radio head unit to turn it on and off with the radio.
When the ignition is turned off, the radio loses power, in turn so does the amp. Also this happens when the radio is switched off with the key on.
The radio has 2 hot leads, 1 is for main power, the other is for memory to retain your settings. I know of some cases where these wires were hooked backwards, then the radio would intermittantly lose its settings and the amp would not turn off properly.
Old Aug 22, 2012 | 07:55 PM
greenslade's Avatar
lacking an amp meter,you could use a test light connected in series with bat- to - cable,if you have a draw the light will light up,the bigger the draw the brighter the light.not as good as a amp meter but will work in a pinch.
Texas442
Mar 28, 2013 07:13 PM
b350m
Aurora
Aug 3, 2011 03:04 PM
w-30dreamin
Jan 9, 2010 03:19 PM
bermuda
May 18, 2006 11:38 AM
