Dome Light/Front passenger turn signal.
I'm having two issues that I want to tackle this weekend.
Car: 70 442
1) The dome light sometimes turns on when I open the driver door and sometimes it doesn't. (Majority of the time it doesn't). BUT it always turns on when the passenger door is open, so it's just an issue with the driver door. What can be causing this? Where do I start?
2) The front passenger side turn signal doesn't blink when I'm giving a signal. The light does turn on at night and the green arrow on the speedo works, it's just that doesn't give a flashing signal up front. Bad bulb and or wiring?
Thanks. I've been learning a lot from this board.
Car: 70 442
1) is likely the pin switch on the drivers door. It has a spring in it so perhaps that is weak or broken. It can be unscrewed easily enough for inspection.
The switch should look something like this:
costpenn
June 24th, 2015 10:38 PM
Xiw
December 30th, 2008 12:56 AM
