Turn bulb and Dome light Problem
Old Jun 18, 2011 | 11:32 AM
richeyb's Avatar
I have restored a 72 Cutlass and have just about all the electrics working. Just 2 problems
1. The front right trun signal bulb will not stay engaged. I have used the grease packets they have for bulbs but still shakes loose and loses connection. Any tricks short of replacing outlet???
2. Dome Light fixture replacement. I have ordered replacement Dome Light lens and Dome Lens housing from Fusick, surprised that it did not inlcude the electrical connection to hold the bulb... Do I have to buy the whole wiring harnes to get the connection and then brad it into the housing or does someone sell the compete unit???? I checked Year.one and they offer the same housing.
Thanks,
Richey
Old Jun 18, 2011 | 01:12 PM
1. Check the solder terminals on the base of the bulb. Sometimes they wear down, causing the bulb to be loose. Failing that, it's probably time for a new socket.
2. The terminals snap out of the old housing from the back and snap into the new housing. They are part of the harness.
Old Jun 18, 2011 | 01:13 PM
scott71's Avatar
question
Hey i don't have an answer for you but i can't get the dome light cover off, how does that come off????? I've got a 71 cutlass, its a round dome light, i'm assuming its the same. Thanks
Old Jun 18, 2011 | 06:19 PM
It just snaps in place. Pry gently with a small flat blade screwdriver.
Old Jun 18, 2011 | 07:02 PM
scott71's Avatar
i tried again before reading this post and it came right out this time, the lens is starting to look brittle though. It was driving me crazy, those are the things you don't want to break cause they cost like 20-30 bucks for nothin. Thanks
Old Jun 19, 2011 | 08:22 AM
Unfortunately, the plastic does get brittle with age.
rkk69olds
Jun 21, 2014 04:11 PM
Massdelta
May 27, 2014 02:14 PM
mauls
May 31, 2011 02:10 PM
tim72
Apr 27, 2010 05:40 AM
Pfiffle
Oct 5, 2009 04:32 AM
