Dash clock issue
Old January 20th, 2023 | 10:45 AM
72455's Avatar
Dash clock issue
Hey all I took my '72 Supreme to work today, and I noticed an issue with my dash clock. It was working fine up until this morning, but while I was driving, I noticed it stopped. I reset it and it started working again, but after about 2 or 3 minutes, it stops again, and all I have to is pull the **** to get it going again. But again, after 2 or 3 minutes, no tick tock.
I have 2 working spares, so is it worth the time to troubleshoot, or should I just swap it out and call it a day?
Old January 20th, 2023 | 11:28 AM
Have it converted to quartz. The contacts in the original electromechanical clock arc and pit over time. I'm more impressed that you had one that was working up until now!
Old January 20th, 2023 | 12:17 PM
72455's Avatar
I know the contacts arc and pit over time, so would this explain why it starts working when I pull the ****? And FYI Joe, the clock has been in for about 2 years, so I guess that's a reasonable expectation? As far as the quartz conversion, I'm too "old school" to do that... that's why I have extras in my stockpile. 😁
Old January 20th, 2023 | 12:49 PM
VC455's Avatar
Gary
When you pull the ****, there's enough vibration to cause the points to conduct that one time.
If you run out of extra clocks, use a points file to restore the point surfaces.
Old January 20th, 2023 | 01:06 PM
DOH! NVM...
Old January 20th, 2023 | 02:21 PM
Relax, the quartz conversion is easy. And removing a clock from a 70-72 A body is about as easy as it can get.
Old January 20th, 2023 | 03:06 PM
Anybody have any recommendations on quartz conversion companies? I know there are different options.
Old January 20th, 2023 | 06:25 PM
Toms cutlass's Avatar
I installed a quartz conversion from this company: https://www.clocksandgauges.com/quar...rsion-kit.html
I used kit S-3015 for the tic-toc-tach. See below. It’s available direct from the manufacturer and it is offered by them on eBay. https://www.ebay.com/str/clocks4cars...75.m3561.l2563
I did the clock quartz conversion even though the original electro-mechanical clock movement worked. I got tired of having to reset the correct time to synchronize the movement to keep accurate time. I’m happy I did.
Old January 21st, 2023 | 07:53 AM
$90 isn't too bad. Even paying shipping I'd pay less than $300 to convert both clocks in my 98! Definitely on my to do list!👍
Old January 21st, 2023 | 06:20 PM
72455's Avatar
Just to give an update (and to get this thread back on track), I dunno what happened, but all the way home from work yesterday, it worked fine. Checked it tonight and it's still ticking along.
Old January 21st, 2023 | 06:54 PM
If it was literally only 2-3 minutes as you said between when it worked and when it stopped, that’s far less than the time between when the points contact and refresh the winding mechanism. The movement itself may be getting hung up somewhere and the friction points need cleaning and clock oil. If you have working original spares, and you want original not quartz movement, why hesitate to replace the clock when it’s a 5-minute job?
Old January 21st, 2023 | 07:01 PM
72455's Avatar
If the movement was getting hung up, then wouldn't it have stopped either on the way home or from the time I parked it last night to when I checked it tonight?
Old January 21st, 2023 | 07:15 PM
If it’s binding in the movement, it could be intermittent. When you pull the adjusting stem you could be relieving the binding. Another possibility is an intermittent bad ground on the clock case with the ground strap. At night, do the lights in the clock work? Has the clock ever been opened up?
Old January 21st, 2023 | 08:04 PM
72455's Avatar
Yup, the lights on the clock work, and yes, it has been opened up. I bought it reconditioned.
Old January 21st, 2023 | 08:07 PM
72455's Avatar
Ok, if it was intermittent, then it would run slow, correct? Because when I checked it tonight, it showed the correct time
Old January 28th, 2023 | 06:53 AM
72455's Avatar
And the saga continues....I haven't swapped the clock out yet, and when I checked it a couple days ago, it wasn't ticking. No big deal..I was gonna swap it anyway.
I started it up today to take it to work, and the clock starts working. Also, I heard the points click while I was waiting for it to warm up, so if they were stuck shut, I wouldn't hear the click, correct?
I've been at work for 2 hours now, and I checked it...still ticking and it's keeping correct time.
Old January 28th, 2023 | 09:04 AM
Bfg's Avatar
Bfg
Takes a licking and keeps on ticking, buy a Timex
Old January 28th, 2023 | 01:35 PM
VC455's Avatar
Gary
Engr
...I heard the points click while I was waiting for it to warm up, so if they were stuck shut, I wouldn't hear the click, correct?
The points only stick shut when you allow the battery to run down completely while connected to the car. This can also burn out the electromagnet that winds the clock spring.
The more common problem is that the points oxidize and don't conduct electricity even though they are closed. Occasionally, vibration starts them conducting again. This is what probably happened to yours.
cublex
January 1st, 2021 08:45 AM
salb58
November 18th, 2019 08:59 AM
72455
April 3rd, 2019 09:03 AM
rmoths
January 2nd, 2012 09:29 PM
Red_Canti
May 17th, 2011 08:19 PM
