Courtesy Lamp lens removal 1970 98
The outer plastic chrome finished retaining surround is screwed into place into the arm rest quarter section. Use a small screwdriver to pry the white translucent lens from the chrome finished retaining surround - in the small slot between the lens and the surrounding chrome finished retainer. Use of a flashlight is appropriate and get close so you can 'witness' the white translucent lens beginning to 'give way'. Just be careful and nudge it ever so slightly on either the left-hand or right-hand side and be mindful to watch the lens flex as it gives way from the surrounding retainer.
