Courtesy Lamp lens removal 1970 98
Old Mar 23, 2020 | 04:50 PM
tchagerman's Avatar
I promise I'll buy the service manual soon... in the meantime does anyone know the trick to accessing the burnt out bulb behind this lens?
Old Mar 23, 2020 | 05:31 PM
tchagerman's Avatar
Lined a wide flat head screwdriver with electrical tape and carefully popped the lens cover off from the underside. The bulb was still working just not twisted in place properly,
Old Mar 23, 2020 | 05:50 PM
The outer plastic chrome finished retaining surround is screwed into place into the arm rest quarter section. Use a small screwdriver to pry the white translucent lens from the chrome finished retaining surround - in the small slot between the lens and the surrounding chrome finished retainer. Use of a flashlight is appropriate and get close so you can 'witness' the white translucent lens beginning to 'give way'. Just be careful and nudge it ever so slightly on either the left-hand or right-hand side and be mindful to watch the lens flex as it gives way from the surrounding retainer.
first442
May 31, 2026 09:30 PM
kansjfr
Nov 22, 2014 07:10 AM
milesmonte
Sep 23, 2013 09:53 PM
Benton Quest
Apr 2, 2013 04:02 PM
Propaneking
May 6, 2012 05:14 PM
