Comfortron HELP!
Old April 22nd, 2009 | 10:06 AM
pw69olds's Avatar
Exclamation Comfortron HELP!
I have a 69 Olds 98 with comfortron. When I rotate the Temp dial on the controller, does anybody know if I should get a variable voltage to the transducer? If so, what is the voltage range from hot to cold? Also, transducer then modulates vacuum - can you tell me what psi range vacuum I should get at each end of the spectrum? Thanks Paul cm2chicago@aol.com
Old May 8th, 2009 | 08:50 AM
Oldsguy's Avatar
Past Administrator
Paul,
Your post is the second one I have noticed today that I missed. Sorry for not welcoming you to CO so I am doing so now. I will move this thread to the appropriate forum and perhaps you will get a reply.
Old May 9th, 2009 | 09:28 PM
bigoldscruiser's Avatar
2 '66 98's
Paul, I posted an answer to your questions last night but it is not here now. I don't know if you saw it or not. If you still need the info, send me an e-mail.
Bruce bruceb.66@verizon.net
Old February 10th, 2023 | 08:14 AM
Jody Amblard's Avatar
You should see the voltage to the transducer vary between 0 VDC at full heat and 10 VDC at full cold. However, a 3 - 8 VDC is sill acceptable. Please make sure that your transducer is grounded - the 2 bolts to the firewall are usually its ground, but they get rusty, so I would connect a separate new lead from the body of the transducer to a good ground under the dashboard.
Old February 10th, 2023 | 09:05 AM
Your first post here resurrected a thread that is nearly 15 years old. I hope he got it fixed by now.
Old February 10th, 2023 | 10:53 AM
I know what you mean, Joe. Cheers, jody
tbristol
April 11th, 2014 02:27 PM
wojmar
May 30th, 2013 06:52 AM
Swede98
Ninety-Eight
20
April 3rd, 2011 03:27 PM
whojohnjones
Ninety-Eight
August 8th, 2010 01:26 PM
silverriff
June 10th, 2008 04:11 PM
