a/c just died in 85 delta 88
Old Jun 24, 2010 | 03:24 PM
agtw31's Avatar
drove the car for awhile this morning with a/c blasting
got in this afternoon and nothing,compressor will not kick on
put a new relay in,and replaced the 2 prong connector at the compressor
both of them were pretty melted up
still nothing
where do you check for 12 volts?
at the relay??
Old Jun 24, 2010 | 06:15 PM
still nothing
at the relay??
The first thing to check for is adequate freon pressure in the system. If the freon has gotten low, the pressure switch will prevent the compressor clutch from engaging.
Old Jun 24, 2010 | 06:51 PM
jensenracing77's Avatar
X2
Old Jun 24, 2010 | 07:05 PM
Gaz Hog's Avatar
Yeah, often when pressure is low (due to low freon), the compressor won't kick on. Had this happen in two of my cars.
Old Jun 25, 2010 | 02:30 AM
you can jumper the pressure switch with a short wire or paper clip to see if it turn on. if it does then you need more refrigerant. just don't run it like that. you can find the pressure switch on one of the lines, most of the time on the older cars, tord the front.
Old Jun 25, 2010 | 08:29 AM
agtw31's Avatar
i tried the pressure switch trick,got nothing
my a/c has always been freezing cold,i cant see low freon charge being the culprit an hour after i drove it
i think it's electrical,im just trying to figure where else to look
Old Jun 25, 2010 | 08:47 AM
agtw31's Avatar
i got the compressor clutch to come on running 12 volts straight from the battery
so now what?
Old Jun 25, 2010 | 08:56 AM
Blk71SX's Avatar
first, make sure you're getting 12 volts TO the relay when the dash switch is on ac. if so, then check for 12v out
Old Jun 25, 2010 | 09:08 AM
agtw31's Avatar
i have 4 prongs on the connector coming from the EMC to the relay
2 of them have juice.
i orderred a low pressure switch,it will be here in 2 hours.
and im going to try that retrofit kit and charge it back up.
Old Jun 25, 2010 | 03:07 PM
agtw31's Avatar
replaced cycle switch and relay,filled up with freon
still nothing
i think i have a melted wire some where
Old Jun 26, 2010 | 06:21 AM
Lady72nRob71's Avatar
I assume no check engine light...
Melted stuff is bad. Did you replace the connector at the relay? How did it look? If the terminals in the melted connectors are blackened, then contact will be inhibited.
Use a jumper wire to ground the brown wire from the relay to ground. If compressor engages, ECM is not telling the A/C it can work, or a bad connection between the two.
Ohm out your compressor clutch coil - they sometimes burn open.
Pretty simple circuit - here is the diagram...
Tom442
Jun 21, 2015 11:44 AM
CEOJOE
Jul 29, 2011 08:39 AM
67cotlass
Jul 24, 2007 03:40 PM
67cotlass
May 13, 2007 11:05 AM
gajeep
Mar 17, 2007 07:30 PM
