Blower motor SQUEAL!- 68 442
Old May 23, 2010 | 10:25 AM
JBrooks's Avatar
I have a '68 442 convertible with factory A/C.
The blower motor has an awful squeal at virtually all speeds.
I am assuming the motor will need replaced.
Does anyone know how difficult this replacement is and a recommendation for a vendor to supply the motor?
Thank you.
Jim
Old May 23, 2010 | 05:13 PM
Thank you.
Jim
Unfortunately, this is one PITA job. You need to remove the passenger side fender, or at least the inner fender, to access the blower motor. Expect to have at least one clip nut start spinning.
I would also suggest that if you go that far, you MIGHTASWELL replace the heater core at the same time, since it also requires the fender to come off (to access the bottom bolt on the box).
Old May 23, 2010 | 06:43 PM
bgoble's Avatar
Joe... is the same true for a 72 Cutlass?
Old May 23, 2010 | 07:48 PM
JBrooks's Avatar
Thank you, Joe.
I genuinely appreciate your response, although I wish the message were a bit better.
Thanks again.
Jim
Old May 23, 2010 | 08:43 PM
Yup, same PITA location. Green wire feed. Bolted in just behind the passenger side wheel cover. I'm doing the same thing Joe recommended; changing the heater core at the same time when I do mine.
Old May 26, 2010 | 06:50 PM
Kace's Avatar
Hey, Have same car, I have a purple wire going nowhere near fender on a/c side. Any idea what it's for?
Old May 26, 2010 | 07:13 PM
Best guess
Sounds like it may be part of the hi blower relay?
DSC01889.jpg?t=1274926378
Old May 26, 2010 | 08:03 PM
bmort's Avatar
purple wire
mine plugs into the little "pig tail" condenser right above the purple wire on my tire.
Old May 27, 2010 | 02:59 AM
Yellowstatue's Avatar
To prevent the clip nut from spinning, put a 1/2 inch box wrench (six point) on the nut first and if your arms are short on one end then have a helper operate the ratchet whilst you hold the wrench firmly to prevent spinning... of course this is on an original '68 clip nut...
JuzCallMeDee
Mar 26, 2013 02:25 PM
Johnny Cage
Feb 28, 2013 02:28 AM
deltaboy
Feb 6, 2013 01:01 PM
kplange
Jan 7, 2012 07:11 PM
hunter
Nov 18, 2011 11:45 AM
