Blower motor access
Old Nov 16, 2011 | 03:06 PM
pistonpop's Avatar
Blower motor access
Can someone tell me if I need to remove the fender when replacing the blower motor on my 71 cutlass S? Or just the fender wheel well? My Mchanic does not want to do the job! I turned wrenches the younger part of my life, for about 10 years, but don't feel like doing it either!
Old Nov 16, 2011 | 03:49 PM
qjetolds's Avatar
U just need 2 remove inner fender not 2 bad of a job!
Old Nov 16, 2011 | 04:06 PM
pistonpop's Avatar
Old Nov 16, 2011 | 04:15 PM
DJS70cutlass's Avatar
sounds like it's time for a new mechanic
Old Nov 16, 2011 | 05:23 PM
Lady72nRob71's Avatar
I would not blame the mechanic if removing the fender was the only way to change the motor - too much liability is at stake for damaged paint or mismatched body panel lines.
Pull that inner fender! The right side is not too hard - about 10 bolts or so, pluss a couple of clips for the A/C hoses. In fact the well does not even have to be pulled out - just loosened all the way so it can get pushed around and pivoted down at the front so the back side is upwards for access. Motor is right behind the wheel afterwards.
I think you can do it yourself easily. In fact, pul lthe wheel and wheelwell completely. Then not only can you replace the motor, but you can remove the whole heater/AC box for cleaning... An oven cleaner bath on the plastic wheelwell will clean it like never before.
Repaint your frame? Rebuild the suspension? All possible while that inner well is gone.
I think i should shut up now..................
Old Nov 16, 2011 | 06:14 PM
pistonpop's Avatar
Thanks everyone. I think I'll wait for the winter to set in and get to it. I guess I just needed a little push!
Old Nov 17, 2011 | 06:12 PM
2blu442's Avatar
You may have to fight rusty bolts if your car has been driven much when the roads are salted. Most fasteners you'll not be able to reach the back side of to soak with penatrating fluid. Good luck and let us know if you run into any questions when your pulling it. John
Old Nov 17, 2011 | 06:13 PM
2blu442's Avatar
Uh... does the phrase "might as well" come to mind
Old Nov 17, 2011 | 06:15 PM
You called??
oldzy
Site Help
Sep 14, 2009 10:48 AM
erudek
Aug 28, 2009 05:45 AM
1971 sienna conv
Site Help
May 18, 2009 03:04 PM
edgewoodrx
Site Help
Apr 25, 2009 05:19 PM
bucknailer
Sep 26, 2006 04:36 PM
