Battery Draining Continually
Old Sep 21, 2023 | 09:22 AM
lowden's Avatar
We have a 1968 Oldsmobile 442 and the battery in discharging continually. We are in the process of installing a new Optima Red Top AGM Battery to see if it helps, but has anyone else has this problem? BTW - we don't have anything running except the clock on the dash.
Thanks for the help!
Old Sep 21, 2023 | 09:26 AM
redoldsman's Avatar
Proud Viet Nam Veteran
You have a parasitic drain somewhere. Pull the fuse to the clock and then disconnect the positive battery cable. See if you have a slight arch when you touch the battery cable to the battery. If you do, start pulling fuses until it disappears. Then you have found the culprit.
Old Sep 21, 2023 | 09:29 AM
skyhigh's Avatar
1972 Cutlass Town Sedan
It would probably help if you give more details like is your previous battery really old, could have bad cells and wont charge properly, what's the volts on a full charge?, is your Alt charging properly etc, cant hurt to buy a new battery.
Old Sep 21, 2023 | 09:34 AM
Also, what condition are your battery cables in? Crispy, burnt terminals with green oxidation and split jackets is a NO NO.
Old Sep 22, 2023 | 04:56 AM
cfair's Avatar
Speaking from 66 big car experience, my wiring colors may be off, but I believe the principle may help…
One culprit I’ve found along the way if it’s not the clock are the door jamb courtesy light switches. They physically move their orange and white wires every time you get in/out of the car.
In my big cars, these are the 2 pin plunger switches which I think were new in ‘66 because my 65 wiring harnesses had much larger diameter different switches.
As designed, there is very little clearance between those wires and the steel body which can cause them to ground when their insulation frays.
As noted above, pull the courtesy light fuse to test if this might be your problem.
Chris
Old Sep 22, 2023 | 06:10 AM
leftlaneonly's Avatar
With the battery charged remove both cables and let sit overnight. In the morning check the voltage for a drop. This may show it's the battery not the car
ericisback
Sep 10, 2022 07:53 PM
J1978
Dec 24, 2021 09:13 PM
PM70
Jul 10, 2020 08:02 PM
Neil Morrison
Feb 28, 2020 06:35 PM
The_Avaricious88
Aug 26, 2011 12:39 PM
