battery drain
battery drain
My 84 Olds Royale Brougham keeps draining the battery when I drive. I drive to work and then turn the key and no go. Its a new battery, the alternator checked out good. When I touch the batt cable to the post there is no spark.
Pull the dome light/courtesy fuse.
Disconnect a battery cable.
Place an old school, actual test light with a bulb in series between the battery and the disconnected cable. If it lights, there is a draw. Pull and replace fuses until the light goes out. Troubleshoot that circuit.
If the light does not light, the problem is in the courtesy circuit (dome light, lighter, radio memory).
