Battery discharged in the morning.
I put a 2.2 µF one on the outside, screwed to the case and connected to the plus terminal. A second one was connected to the open old external regulator plus connection, which I put on first, and left there.
Neither did a change. I noticed that the one inside the old generator was .5 µF, is 2.2 too much?
The classic alternator sound is a siren like whine that is RPM varied. Static crackling can be non-resistor plugs or solid copper plug wires. Thumps, holes? I got nothin'. There are "filter" devices available that go in series with the radio power input line. You can try a hand-held AM radio tuned off-channel moving it around under the hood to see if you can spot the offending "transmitter".
I figure it's my ignition, then. Spark can jump from one wire to another if they touch, yes? Might that give me noise? I have 8mm HEI wires, and a type of spark plug of the same specs as R46SZ.
Yes, older cracked wires with broken down insulation can arc between each other or to a ground source. You sometimes can see the arcing looking at your wires at night or in a dark garage. Try spraying water on the wires with a mist bottle BEFORE testing. It often reveals the lightning storm enhancing conduction.
Oh, and probe around with an insulated stick or something while testing. Handling wires with you hands can make for shocking results. (Ask me how I know).
59Olds98
Dec 25, 2013 08:20 AM
jensenracing77
Feb 17, 2011 05:26 AM
