Battery Cable Question
Old Mar 31, 2012 | 05:33 PM
Al Graaf's Avatar
Formerly "Shimmer"
71 442 455- I've noticed that the cables listed with M&H as well as INT show or list the positive cable as spring ring and the negative as a post connector. Am I missing something here? I thought they were both spring ring. The cables are at least 2ga, possibly 1 or 0. the positive cable is indeed a spring clamp but the negative is a side approach bolt type clamp. the original battery size wouldn't allow access to a spring clamp.
Old Mar 31, 2012 | 06:48 PM
joepenoso's Avatar
\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\good luck ............I couldnn'tfind the + battery cable length on a 1971 442 auto?????????????????
joepenoso
Old Mar 31, 2012 | 07:02 PM
Shimmer, positive is spring ring, negative is post connector, as they indicate, earlier cars were spring ring for both.
Old Mar 31, 2012 | 07:03 PM
Call Fusick and ask
Old Mar 31, 2012 | 07:15 PM
Al Graaf's Avatar
Formerly "Shimmer"
Have any idea why they changed? Was thinking about going to side post as this was the change over period. But want it to be original. Thanks for the reply!
Texas442
Mar 28, 2013 07:13 PM
w-30dreamin
Jan 9, 2010 03:19 PM
1968 42
Apr 13, 2008 12:19 PM
