Audio Expert
Was there a picture ment to be included? Just FYI unless its a Subwoofer, anything covering any part of the dome/tweeter will interfeer with sound, if the metal is low enough, and you blast the speaker, the doam my hit the metal causing perminate damage. But I can't tell you if its in danger without seeing a pic.
Well, you've got one tweeter completely blocked, so you won't hear that one at all.
How important that is to you, compared to cutting bits off the car, is up to you. I'd listen to it as is and decide whether the sound is good enough that way before making any decisions.
You might consider a speaker system that puts the midrange and tweeters in different places, to get around this problem.
Given that both the "tweeters" on that speaker produce the same frequency, you really aren't losing much. Make sure the speaker is spaced enough away from the deck that under full excursion it's not hitting the metal and you should be ok.
What are you putting over top of the rear deck? make sure it's got some sort of opening or you may as well not have put speakers there at all.
Even if the two tweeters are identical and are crossed over for the the same frequencies, covering one will reduce that range by about 50% (maybe 40%), which will affect the sound. If your speakers had an adjustable crossover (unlikely), you could turn them up to compensate, but then you would risk overdriving them on loud passages and ruining the sound that way.
if you are concerned maybe clear a bit of metal out from above the tweeter, or just make a proper 6x9 hole.
1957 Super 88
June 4th, 2013 05:43 PM
auto_editor
January 30th, 2013 11:02 AM
