Another misfire thread
Old August 12th, 2022, 07:45 PM
oletrux's Avatar
I'm chasing the same problem with my fresh 455, but it's simply a misfire, not a timing skip.
I'm down to changing the ignition to an MSD ready to run points-style dizzy with a simple 6A box. Added a Blaster 2 coil.
Does my car (72 wagon) have a resistance-wire in the ignition circuit? Does it matter, except for starting?
I've been a bit under the weather (it's been awhile), but here's what I remember from my install:
Gray wire from bulkhead connector (I assume) to coil positive.
Yellow wire from starter solenoid to horn relay.
Power wire from alternator and starter also to horn relay.
On a side note, the car had an HEI before with a working tik-toc tach. It is no longer inoperative although wired to the negative side of the coil.
Engine to chassis, engine to body grounds are good.
oletrux is offline
Old August 13th, 2022, 05:27 AM
You may want to start your own thread, but here's the 1972 wiring diagram for you to consider (located in the Electrical Forum):
https://classicoldsmobile.com/forums.../#&gid=1&pid=1
EDIT: Wiring Diagram Image
Vintage Chief is offline
Old August 13th, 2022, 10:04 AM
I moved your post to it's own thread.
If there was an HEI installed, it should not have been using the stock resistance wire. Yes it matters.
Gray wire needs to be a 12/14ga and from a 12v keyed source.
The yellow wire was the original resistance bypass wire that ran from the starter R terminal to the coil+ terminal. It can be removed.
If your tach is inop, it may be the cause of your misfire. Try disconnecting it.
oldcutlass is online now
Old August 13th, 2022, 11:49 AM
oletrux's Avatar
Thanks.
Some more info for you.....
the existing gray wire looks only to be about an 18 gauge wire.
This intermittent misfire has been in the car since I bought it.
Well, I took the plunge and removed the engine harness. Sure enough, the gray wire was open somewhere. Finally found continuity about a foot from the bulkhead connector. I am now waiting on the terminal I need to reinstall an ignition wire back out to the coil.
My bet is that was the problem all along.
Thanks for the tip on the tach.
Think I might just sick with the Pertronix for now.
Thx guys.
oletrux is offline
Old August 20th, 2022, 07:58 PM
oletrux's Avatar
Nope, still got the misfire. Seems worse when the engine is not working hard. Solid during acceleration, but cruising about 40 in 4th gear will beat you to death.
What do you guys use for initial timing? I'm at 14° with the vacuum advance blocked off. Total timing at 3,000 rpm is about 31 or 32°.
oletrux is offline
Old August 21st, 2022, 06:17 AM
Total mechanical timing is measured at the rpm the distributor stops advancing. An un-modified distributor can do this past 4000 rpm.
Old September 21st, 2022, 07:54 PM
oletrux's Avatar
Still screwing with it.
Replaced the ignition resistor wire with a 10ga braided wire.
No change.
Installed the MSD components.
No change.
Reinstalled the old GM HEI.
No change. Plan to return to the mechanical only MSD distributor.
Carb is running pig-rich......and the car will get some professional tuning Monday. I'm sure this is a contributing factor but.....
Meanwhile, I'm wondering if the ignition switch (not the key switch) could be the problem. Any experience with that? The car has had a low-speed misfire with two different engines, three different ignition systems, and two different carburetors.
As always, thanks guys.
oletrux is offline
JkWheels
February 7th, 2021 01:36 PM
Tjohn8573
January 22nd, 2021 01:21 PM
JeremyTA
August 17th, 2011 06:04 PM
defiant1
May 3rd, 2011 08:52 PM
cstnzo
July 12th, 2008 09:22 PM
Quick Reply: Another misfire thread
