AM radio Help
Old Apr 21, 2012 | 04:47 PM
harry442's Avatar
AM radio Help
I am working on a 1970 442. I have an Am radio with an 8 track. Both work fine. The problem I have is when I ground the 8 track the Am radio doesn't play??? If i un ground the 8 track you cannot hear the 8 track play? Any help??
Old Apr 21, 2012 | 04:50 PM
How's your ground on the radio? I'm guessing you have the under dash factory 8 track?
Old Apr 21, 2012 | 04:54 PM
harry442's Avatar
Yes it is the under dash 8 track. I grounded the radio to the case and still the same thing?
Old Apr 21, 2012 | 05:15 PM
Have you checked your speaker connections?
Old Apr 25, 2012 | 03:30 AM
harry442's Avatar
Both speakers are hooked up and work fine??
Old Apr 27, 2012 | 04:13 PM
Have you tried grounding both units at the same time???
Old Apr 27, 2012 | 04:30 PM
I'm assuming that your speakers are tied to ground.
Old May 1, 2012 | 03:10 PM
radioburningchrome's Avatar
Sounds like a floating ground. I had a similar problem when wiring an amp to my stock radio and aftermarket tape deck.
You need to install a "floating ground adapter" - like this:
http://www.amazon.com/DLC-Floating-G.../dp/B002AU9W3O
Old May 3, 2012 | 04:38 PM
Wouldn't that do the same thing as grounding both units?
Old May 4, 2012 | 05:47 AM
harry442's Avatar
Thanks so far for the info. I have tried to ground both units and the radio does not work. If I unground the 8 track the radio works, but the 8 track doesnt work? I take that back the 8 track works but no sound from the speakers?
Old May 4, 2012 | 05:56 AM
Tony72Cutlass'S''s Avatar
I know it's a bit of a backyard mechanic's solution. But why not just put a flip switch under your dash that you switch when you want to play your 8-Track.
It's a 0.50$ solution. Maybe not proper but it'll suffice for the meantime.
Old May 4, 2012 | 06:00 AM
stevengerard's Avatar
IIRC there is one wire that goes up to the front center speaker and the speaker itself is grounded, that's how the radio gets grounded. There is a separate ground wire for the 8 track player
Old May 4, 2012 | 11:04 PM
It would appear to be-yes. Never tore apart a floating ground adapter.
They do solve those weird problems.
Old May 4, 2012 | 11:05 PM
To avoid any further problems, take the speaker grounds and run them throught the floating ground adapter.
Radio gets a ground from the chassis.
dnmfranco
Jul 2, 2014 05:10 PM
dancutlass
Oct 2, 2012 02:49 AM
sx455raidercelticfan
Jul 29, 2010 07:44 PM
tim72
Jun 29, 2010 01:40 PM
blessedfind
Jun 4, 2010 12:13 PM
