Radio wiring need help
Old Jun 29, 2010 | 11:07 AM
tim72's Avatar
I bought a new Kenwood radio and it has two wires I am having an issue with. One wire goes to battery and one goes to ignition. Can somebody tell me what color wire in the dash wiring the ignition wire would go to? Can somebody tell me what color wire inder the dash the battery wire would go to? there is the original Radio wire and I do not know if that is ignition or battery. I am pretty sure it is Ignition because the radio turned on with the key. That would leave me with what color wire the battery wire on the radio would hook up to.
Old Jun 29, 2010 | 11:21 AM
Lady72nRob71's Avatar
Given your code name, i assume you have a '72.
If so, then battery (constant 12V) is a big orange wire going to clock, lighter, and courtesy lights.
Switched 12V ("ignition") would be yellow, the wire that went to the original radio.
Old Jun 29, 2010 | 01:40 PM
tim72's Avatar
Thank you! I had that wrong!
EightyEightCut
Aug 23, 2012 10:22 PM
Lady72nRob71
Jan 23, 2011 07:45 AM
dallas6778
May 21, 2007 02:18 PM
TIREGUY
Dec 16, 2006 04:10 PM
