AM/FM Radio help
Old May 19, 2011 | 04:57 PM
Jacoz70442's Avatar
AM/FM Radio help
Hi, brought a Wonderbar AM/FM radio from a 69 B-body(model #93BFW2) and wondering if there is any special work I am going to need to do to make it work for my 70 442? Visually looks very close to the 70, and any help with differences would be greatly appreciated. Thanks for all the help.
Old May 19, 2011 | 09:41 PM
stevengerard's Avatar
there might be some visual differences, mostly the *****, there were a few different types. If it was a AM/FM mono unit and you only have the one main piece then you are ok. If it is a true 69 stereo I believe they had an additional amplifier like the ones from 1970. On the a-bodies those amplifiers mounted up near the glove box. Once mounted in the car you'd never know though anyway
Old May 20, 2011 | 03:07 AM
Yellowstatue's Avatar
The problem with B-body car radios is the fact that the heat sinks are on the passenger side of the unit and when you try to install them into a Cutlass the heat sinks hit the brace that is along side the glove box...so you would have to bend or cut the brace to solve the interference...
Old May 20, 2011 | 05:00 AM
Jacoz70442's Avatar
Thanks guys. I'm going to check it out. I have the entire dash assembly on my workbench restoring, so should be easier to see.
dnmfranco
Jul 2, 2014 05:10 PM
dancutlass
Oct 2, 2012 02:49 AM
sx455raidercelticfan
Jul 29, 2010 07:44 PM
tim72
Jun 29, 2010 01:40 PM
blessedfind
Jun 4, 2010 12:13 PM
