Alternators
Old Jan 12, 2014 | 04:27 PM
Stevec's Avatar
Alternators
I've got a new engine coming soon and will be upgrading/installing the following:
Aeromotive stealth in tank fuel pump setup.
4 core radiator with dual 13" Spal fans.
All new Msd ignition.
My question is should I go with a larger alternator to keep up with the increased demand to run all these aftermarket accessories?
If so what size alternator should I run?
Where can I get one?
Need some info/suggestions.
Old Jan 13, 2014 | 09:30 AM
Yes, you probably do want to upgrade the alternator, along with the wire from the alternator to the junction block. I strongly suggest NOT getting a one-wire alternator, unless you don't want it to charge at idle. I like factory style alternators, either 12SI or CS130. Either will bolt to your stock brackets with no modifications, though the 12SI looks more like the original.
There's a 94 amp 12SI, used on the 1986-87 Caddy Fleetwood Brougham with the Olds 307. Remy P/N 20269, $61 plus core for a reman from RockAuto.
There's a 105 amp CS130, used on the 1989-90 Custom Cruiser with 307. Remy P/N 91310, $81, no core for new also from RockAuto.
Old Jan 13, 2014 | 01:44 PM
Stevec's Avatar
Thanks Joe!
Old Oct 22, 2014 | 10:51 AM
512Lac's Avatar
So will these alternator fit a 76 olds 350 motor if they are for a 307?
Old Oct 23, 2014 | 08:47 AM
Well, my original response was to someone who was going to put one in a 1968 442...
Yes, they are both dimensionally equivalent to any external-regulator GM alternator as well as to the 10SI/12SI internally regulated alternators.
507OLDS
Oct 25, 2010 07:15 PM
jensenracing77
Apr 20, 2010 08:56 AM
344870M
Sep 9, 2009 06:18 PM
Dan Wirth
Sep 7, 2009 01:15 PM
dickk
Jun 15, 2007 01:57 PM
