Alternator Wiring Diagram
Old Jun 15, 2024 | 05:42 PM
Bigzo's Avatar
Enzo
I have a 69 442 , the generator light stays on when turning the ignition off and pulling the key. It goes off when engine starts. Amp meter shows it charging . I don’t know if I have it wired correctly. Doesn’t the generator light supposed to go off when key is pulled ? I’d appreciate any help.
I installed HEI , so will wiring connections change ?
Old Jun 15, 2024 | 06:37 PM
Sugar Bear's Avatar
Unplug the alternator, if the light goes out it has a leaking diode.
Installed HEI does the wiring change? The power supply to the HEI needs to be full battery voltage and not supplied through the original pink resistance wire that reduces voltage to prevent ignition points from burning.
Old Jun 15, 2024 | 06:40 PM
Bigzo's Avatar
Enzo
Thank You , I’ll try that in the morning .
teamwieland
Jun 13, 2024 06:40 AM
ShortSmith
Sep 30, 2022 06:22 AM
Michael Birchall
Sep 1, 2019 03:48 PM
Takid455
Oct 29, 2014 07:00 PM
aristellier
Sep 9, 2012 03:49 PM
