Alternator upgrade questions
Old November 15th, 2018, 09:24 PM
big man's Avatar
I've swapped a powermaster alternator - which is internally regulated. My 71 cutlass previously had an externally regulated alternator.
My question is do I need to run fuses or diodes anywhere? No issues as of yet..
I watched a video on how to do so with some of the wiring, but I will be upgrading the charge wire too. I've tested the voltage and it's not quite up to par, only 13.5 volts sometimes lower when accessories kick on.
I'm trying to wire in my sniper, ignition box and dual sync distributor so I'll need the juice.
Also is there any other switched 12v source I could use on the fuse panel. Sniper has to have a source and the ignition box also, or do I just connect both to the same source? Somewhat confusing... Thanks for any tips
big man is offline
Old November 16th, 2018, 06:16 PM
First off which alternator did you install? For the sniper I would use a switched 12v source to power a relay to aux fuse panel, terminal strip, or stud with a 12v feed direct from the battery with the load fused as required.
oldcutlass is online now
Old November 17th, 2018, 04:47 PM
A MSD ignition box will probably require a diode in the charge light wire (the brown wire that went to the old firewall mounted regulator.
Holley wants the power and grind wires run directly to the battery, but sometimes that’s not practical. You could use the stud on the horn relay to power the EFI.
matt69olds is online now
Old November 17th, 2018, 08:18 PM
big man's Avatar
Ok so that stud should be a switched 12v? Any particular way to run the diode? Thanks
big man is offline
Old November 18th, 2018, 05:03 PM
The horn relay stud should have power at all times. The BEST place to get a key on switched 12 volt power is the pink wire coming from the ignition switch. That wire isn’t fused, so make sure to include a proper sized fuse. You could also use the power wire to the ignition coil assuming the resistance wire has been completely removed. Some people like to use the resistance wire to trigger a relay to provide full 12 bolts to the ignition, I don’t like the idea of relays for that. One more thing to possibly fail.
Old November 18th, 2018, 05:46 PM
big man's Avatar
Lol I wish I were more electrically inclined!
So could I use the ignition stud on the fuse panel for the ignition box and the pink wire for the sniper?
Had the sniper running with an Hei distributor but needing a little help on doing the dual sync and ignition box. Both of which are new to me. Thanks thus far..
big man is offline
joepenoso
June 28th, 2013 01:11 PM
lonestarjarhead
March 20th, 2013 07:52 AM
Mark71
April 19th, 2012 07:36 PM
dc2x4drvr
April 20th, 2011 05:37 PM
Oldsproject
July 3rd, 2007 09:53 AM
Quick Reply: Alternator upgrade questions
