Alternator Part number listing
Old Dec 13, 2021 | 12:18 PM
72skytop's Avatar
Hi.
Does anybody have access to or know of an Oldsmobile or all GM inclusive alternator part number list with application that goes from about 1965 to 1990?
I have one Brothers Auto Products by Steve Kenny published many moons ago that is titled: Oldsmobile 1960-1972 V8 Alternator Usage by Application. It is very informative.
I was looking for something that might go a little bit newer like 1973 to 1990....
Any ideas?
Old Dec 13, 2021 | 05:38 PM
What is your actual question? If you are looking for a drop-in, higher amperage, internal regulator alternator, there are two really easy choices. The first is the 94A 12SI used on the mid-1980s Cadillac Fleetwood with Olds 307 motor. This bolts directly to your existing alternator brackets. You'll need to make the wiring mods for a 12SI alternator. The second choice is the 105A CS130 used on the 1989-90 Olds Custom Cruiser with 307. This is also a direct bolt-in with your existing brackets. It also requires wiring mods. Either of these is available at RockAuto for under $100.
Old Dec 13, 2021 | 06:19 PM
Gerald Nickels's Avatar
Answer is 'Motors Manual' in blue
Old Dec 13, 2021 | 06:53 PM
72skytop's Avatar
No. Absolutely not. I don’t know why it is any more that you can’t ask about wanting a list to find the CORRECT numbered date coded part without somebody trying to modify it. Does everything have to be modified or (another word I hate) upgraded? I swear if the words upgraded and modified were taken out of the car hobby, folks outside would think we were mutes.
Old Dec 13, 2021 | 06:54 PM
72skytop's Avatar
That is a reasonable answer. I forgot to look there. Thank you for the reminder.
Old Dec 13, 2021 | 08:28 PM
Just trying to help a Olds guy. Thats where I look first for part numbers.
Old Dec 14, 2021 | 05:32 AM
When you say
that doesn't sound like you want the CORRECT numbered date coded part. The mind reading thing STILL isn't working.
A less ambiguous question might have been "does someone have a list of factory alternator part numbers that covers model years 1973-1990?"
And if you want the CORRECT factory numbers, they are in the factory parts book.
OLDsBARRY
Oct 20, 2021 02:34 PM
RROLDSX
Mar 1, 2017 11:05 AM
lemoldsnut
Oct 20, 2015 08:38 PM
capstoneclub
May 4, 2013 08:39 PM
68CO-HURST
Oct 19, 2009 09:14 PM
