Alternator makes a LOUD squelching sound
Old May 8th, 2011, 06:44 PM
atkinsom's Avatar
I just noticed this happening when I punch the pedal down quickly. I get a loud squelching sound from the alternator area. This only happens if I punch the pedal quickly though not always. I had my wife hit the gas a few times in park while I listened with the hood up and it's definitely coming from the alternator area. I'm new at all this stuff but I assume a slipping belt wouldn't create this squelching sound? (Belt is tight) Just trying to cover my bases...again this only happens mostly when I punch the pedal quickly rather than gradually pushing the pedal down. Driving under cruising conditions creates no sounds from the alternator area.
Thank you for any ideas.
1969 Cutlass S 350 2-barrel
atkinsom is offline
Old May 8th, 2011, 07:16 PM
1968Cutlassfallbrook's Avatar
Well it does sound like it's a slipping belt. Are you sure it's the correct belt? Also what shape is the belt any glaze on the sides where it rests in the pulley?
1968Cutlassfallbrook is offline
Old May 8th, 2011, 07:19 PM
Sounds like a loose belt.
How old are your belts?
How tight is "tight?"
MDchanic is offline
Old May 8th, 2011, 07:24 PM
Big Blue 72's Avatar
I guess I am not sure what you mean by a squelching sound but you could definitely have a slipping belt esp. if it only happens under heavy load. It is a pretty cheap and simple fix so that is where I would start. Please let us know if you need any help and if that fixes it.
Big Blue 72 is offline
Old May 8th, 2011, 08:04 PM
atkinsom's Avatar
Thank you I'll try the belt. It doesn't look too bad but there is some wear so I'll give it a go later this week. I'm pretty sure I can do it myself after watching a couple of videos but if I run into any trouble I'll fire questions in here. Thank you everyone from a real greenhorn
atkinsom is offline
Old May 8th, 2011, 08:20 PM
You should be able to get about ½" movement at the longest span of the belt with firm, moderate finger pressure (not hard pressure) in the middle of the span.
MDchanic is offline
Old May 9th, 2011, 06:04 PM
greenslade's Avatar
also check the groves in the pulley,if it is worn out the belt will ride in bottom of pulley and slip.belt should only contact the sides of the pulley grove.flat side of belt should be just about flush with top of grove.not deep down into pulley.good luck.
greenslade is offline
Old May 14th, 2011, 05:04 AM
atkinsom's Avatar
Good news everyone...replaced the alt belt with a good quality gates and no more loud squelching when the pedal is punched. Thanx everyone you were all spot on
Tightened belt to water pump while I was at it as well
atkinsom is offline
Old November 7th, 2011, 09:06 PM
hushklein's Avatar
i experience this kind of problem. if the noise goes away in a moment, or so, it is probably a loose belt. If it is not too loose it will go away after the battery has recharged.A bad alternator bearing can also make a screeching sound but by the time a bearing gets to that point one had better be getting it fixed pronto. hope that this also helps to solve your problem.
hushklein is offline
Old November 8th, 2011, 05:15 AM
Lady72nRob71's Avatar
Hard, glazed, or ill-fitting belts can slip even when tight. Been there done that...
Gates is a good choice.
Lady72nRob71 is offline
Old November 8th, 2011, 06:38 AM
brown7373's Avatar
And remember, a new belt will stretch after it gets a few miles on it, and will probably need retightening, or it will start to slip also and give you the same sound. Nothing you did incorrectly, Just normal.
brown7373 is offline
allyolds68
August 6th, 2012 03:17 PM
Mark71
June 16th, 2011 11:40 PM
sammieolds
October 4th, 2010 09:56 AM
66ninetyeightls
April 19th, 2010 09:30 AM
Tangovino
July 31st, 2009 03:20 AM
Quick Reply: Alternator makes a LOUD squelching sound
