Alternator internal testing? (internally regulated)
Old July 14th, 2014, 07:24 AM
Seasoned beater pilot.
J-(Chicago)'s Avatar
I have a 5 gallon bucket full of alternators here, and was wondering if there is a simple procedure for testing diode trios, voltage regulators, and rectifiers other than trial and error. Electronics is not my strong suit as I am still ignorant on the subject.
I usually just buy the rebuild kits for 20 bucks and swap everything, but I'd hate to throw away original parts that are still good. Is it as simple as ohming everything out?
J-(Chicago) is offline
Old July 14th, 2014, 07:27 AM
10 and 12 SI models. 73-85
Old July 14th, 2014, 07:36 AM
Oldsmaniac's Avatar
You can check the diodes and windings with a meter. A continuity check can be made on the trio and diode bridge. The meter will only read in one direction and not the other if the diodes are good. The windings can be checked as well for an open this way. The internal regulator cannot be checked with a meter to my knowledge. While operating there is an opening in the rear of the alternator that reveals a tab that is on the regulator that can be grounded. This will put a full load on the alternator and you should should see maximum volt output and also tests to see if regulator is good.
Oldsmaniac is offline
VinMichael
October 24th, 2016 11:24 AM
72cuttys
September 18th, 2014 06:57 PM
dfire25
May 29th, 2013 08:06 AM
danlonchar
October 2nd, 2010 12:34 PM
Quick Reply: Alternator internal testing? (internally regulated)
