aftermarket radio wiring to 69 cutlass
Old May 19, 2007 | 11:31 AM
dallas6778's Avatar
hey all, so im currently tryin to install an aftermarket cd player in my 69 cutlass. ive got the power, and ground hookups all taken care of so the player lights up and works when the cars on. only problem is theres no sound. my car has the single speaker in the dash, with a black ground and a blue wire coming out of it. so i attached all four of the positve speaker wires from the radio (front left and right, rear l+r) to the blue wire out of the speaker. i then attached all the corresponding neg radio wires plus the ground to the black ground coming from the radio. but no sound at all. any suggestions? also when i open the front door there is a loud buzzing noise that only goes on and off when the button in the jam activating the overhead light is depressed. grateful for any tips you can give.
Old May 19, 2007 | 05:39 PM
ozoneblue's Avatar
Question Radio wireing
Try a diffrent speaker .Do not use one with a body ground.As all newer units have floating grounds.Hope you diddnt blow your finals
Old May 21, 2007 | 02:18 PM
dallas6778's Avatar
alright well ive decided to go ahead and install new speakers, only i cant figure out where to put theme. id rather not hack anything apart, and there doesnt seem to be enough room in the door panels. any thoughts on mounting them under the dash?
epinkston
Jul 29, 2015 09:30 PM
Seff
Apr 15, 2015 11:13 PM
defiant1
Apr 23, 2014 04:00 PM
68Dreams
May 27, 2013 11:59 AM
1971 442 convert
Mar 16, 2010 05:56 AM
