87 Buick will not run right
Old August 20th, 2017, 10:25 PM
77ricbaez's Avatar
Very recently my brother's 87 regal (307 olds) started to run really rough when restarted warm, sometimes stalls, but then when hot it runs fine. A few days ago I was driving it and I floored it and the damn car got stuck at 50% throttle. Shut it off, and started it back up and it was back to regular idle.
I checked the code, since the CEL came on, and I got code 21 - TPS signal voltage high
I checked the wires at the TPS and here's what I found:
With the key on
Ground wire - I connected the positive lead of my multimeter to the pos terminal on the battery and the negative lead to the ground at the TPS, I have 12V which tells me that the ECM is providing good ground.
Reference wire - I have 5 volts at the reference wire
Signal wire - when I backprobe it, at idle the voltage is at 0.8-0.9. I increased the throttle slowly and the voltage increase without jumping around. The max voltage at WOT was 3.5. Not sure what the factory specification is, but it seems to me that the range is completely off.
Then when I disconnect the connector, the signal read 4.7v, not sure if this is normal or not.
I would appreciate it if someone could chime in with any advice/ suggestions.
Is the range from the signal completely off? Or does it fall within specifications.
Are there any problems such as a gummed up carburetor that can cause this code to go off?
Honestly am considering ditching the computer for a non computer carb and dist.
77ricbaez is offline
Old August 21st, 2017, 06:30 AM
jcdynamic88's Avatar
it's unlikely the tps is causing any hard starting or rough running,i would look closely at the choke operation.is it open when hot when restarting?check the hot air tube to see if it has vacuum,the port in the baseplate of the carb that feeds the choke housing can get clogged with sludge and won't draw hot air by the spring.also a common problem on those cars is when the purge valve goes bad it causes vacuum to draw fuel out the bowl vent.there shouldn't be any fuel/wetness in the bowl vent hose.
jcdynamic88 is offline
Old August 21st, 2017, 08:20 AM
77ricbaez's Avatar
Even if the computer is throwing a tps code?
Old August 21st, 2017, 08:34 AM
'87 Delta 88 Royale
rustyroger's Avatar
Just because it's throwing a code, don't take it as gospel. Over here 6 cylinder Jaguars will run rough and throw up a faulty O2 sensor code, when all that's wrong is a breather hose split or come adrift.
Check the simple stuff first, rather than throw money at the car.
Roger.
rustyroger is offline
Old August 21st, 2017, 08:40 AM
77ricbaez's Avatar
Roger.
Gotcha
Old August 21st, 2017, 10:39 AM
the computer in your 87 car isn't very smart,nothing like an obd2 car
Old August 21st, 2017, 10:42 AM
77ricbaez's Avatar
Yeah I know, also I have a dumb question, can I spray carburetor cleaner down the fuel bowl vent? Nothing will blow up right?
Old August 21st, 2017, 01:14 PM
you can but i don't know how that is going to help you
Old August 21st, 2017, 01:22 PM
77ricbaez's Avatar
Well if the carb is gummed up it could be why is running rough.
Old August 21st, 2017, 01:26 PM
still think you should verify proper choke and purge valve operation
Old August 21st, 2017, 01:29 PM
77ricbaez's Avatar
Choke is fine, will get back to you on the purge valve
Old August 21st, 2017, 02:12 PM
pull the hose off the top front of carb(3/8 hose) make sure there isn't any fuel in the hose.
Old August 21st, 2017, 02:16 PM
77ricbaez's Avatar
There's no fuel inside the hose
Old August 24th, 2017, 10:35 AM
77ricbaez's Avatar
Just rebuilt carb and replaced the tps and all is well
Chris98Buffalo
June 10th, 2017 08:00 AM
shamusj
March 4th, 2016 06:48 AM
JpMotorsports
June 21st, 2015 07:29 AM
ralsy
June 30th, 2012 04:22 PM
Jayycobb
Drivetrain/Differentials
December 6th, 2011 07:27 AM
Quick Reply: 87 Buick will not run right
