75 Hurst Olds (cutlass) removal of rally gauges
Old Oct 1, 2024 | 05:37 PM
radiofellow50's Avatar
I want to pull the rally gauges out of my 75 H/O dash and I have the 3 screws removed holding that round bezel to the dash but it doesn't seem to want to wiggle or move at all. I don't want to force it or break the bezel. Am I missing one more anchor screw somewhere? The one manual I have says I have to drop the steering column to remove the gauges? Do I have to do that first to remove that rally pack gauge set? I have to get to the gauges as 1. oil pressure and water temp not working. 2. I think a couple of the lights are burned out.
Old Oct 2, 2024 | 09:33 AM
Tuffnut's Avatar
Correct , only 3 holding it in place
Old Oct 2, 2024 | 12:22 PM
Thanks, The unit was in there pretty tight, so stuck the tip of my phillips screwdriver in the screw hole and was able to worm the thing out (worked around the circle doing the same to all three screw holes and it finally budged and there was enough extra slack in the wiring to pull the unit out, disconnect the wiring harness, I cleaned the contacts on the bulbs and the pins on the connector (both male and female). Got it re-assembled now and going to try the gauges once I can start the car. I think the starter is going or bad ground as it seems to want to turn over then just quits (maybe bad spot on the starter?). I changed out all the bulbs but I think it was maybe more bad contacts on the little sockets. Stuck with incandescent bulbs. Some LED bulbs aren't "dimmable" so just left it.
Old Oct 3, 2024 | 12:27 PM
Well, I was either going to fix the gauges or quit....I finally traced the wires, both of the wires (1 to the water temp sensor and 1 to the oil pressure sending unit) were broken! Viola....found the break, spliced in the wires and the gauges are up and running. Someone a while back posted the diagram for the plug on the back of the gauges and that was a big help. Now, onto the next issue, wiring in the tach - have to find 12v switched on when I start the engine! Anyone know where to tap into a source of 12v??
Old Oct 3, 2024 | 03:22 PM
Tuffnut's Avatar
Check the 12v at your wiper motor. I think I used the wiper 12v switched on for my electric choke.
Jeff
Old Oct 3, 2024 | 03:25 PM
Thanks, I'll try and track that down. Did you tap it under the dash somewhere or go through the firewall and tap it out there.
Old Oct 3, 2024 | 03:30 PM
Tuffnut's Avatar
Behind the engine along the firewall.
Old Oct 3, 2024 | 03:38 PM
Ok, I see it, I'll have it hooked up tomorrow!😁
Old Oct 3, 2024 | 03:41 PM
Tuffnut's Avatar
Depending where the tach is located, you may not be any to use the wiper12v feed.
Old Oct 3, 2024 | 06:21 PM
Tach is at the front of the center console so I can get a wire out to the 12v line at the wiper.
Old Oct 3, 2024 | 07:20 PM
Check the fuse box. My car has a terminal labeled IGN that is hot with the key in the ON position.
Old Oct 3, 2024 | 07:34 PM
Ok. Will check that.
Old Oct 4, 2024 | 08:33 AM
Got it done this a.m. Perfect source. Thanks.
ScottM
Aug 26, 2025 06:14 AM
landrysw
Aug 20, 2024 04:17 PM
Bigmikey65
Sep 2, 2022 06:53 AM
damnolds
May 23, 2016 09:29 PM
Ndn_GivR
Mar 7, 2010 05:25 PM
