Rally Pack Bulb Replacement
I need to replace a couple of the bulbs in my 1967 Olds 442 Rally Pack. Is there a way to simply remove just the Rally Pack cluster gauges instead of removing the entire dash?
Be aware that you can do a bit of lighting design by using bulbs of different wattages.
You may want the background light bulbs a little dimmer than the gauge/idiot lights or other preferences.
Assuming you’re using the little blade bulbs which stick into the plastic/brass housings, you might take a moment to bend the brass tabs up a few degrees to restore a tight fit to the circuit boards they fit into.
