Rally Pack Bulb Replacement
Old Aug 16, 2024 | 04:09 PM
landrysw's Avatar
I need to replace a couple of the bulbs in my 1967 Olds 442 Rally Pack. Is there a way to simply remove just the Rally Pack cluster gauges instead of removing the entire dash?
Old Aug 20, 2024 | 07:31 AM
67OAI's Avatar
Old(s)GuysRule
You do not have to remove the dash nor the Rally Pack to change the light bulbs! Just be a contortionist and crawl under, you will find the bulbs each in a small removable housing.
Old Aug 20, 2024 | 04:17 PM
cfair's Avatar
Be aware that you can do a bit of lighting design by using bulbs of different wattages.
You may want the background light bulbs a little dimmer than the gauge/idiot lights or other preferences.
Assuming you’re using the little blade bulbs which stick into the plastic/brass housings, you might take a moment to bend the brass tabs up a few degrees to restore a tight fit to the circuit boards they fit into.
Ontario69Hurst
Jul 22, 2021 05:49 PM
Bandit60
Jun 8, 2021 01:27 PM
slaughter442
Feb 28, 2017 07:40 AM
neatolds
Aug 26, 2015 06:01 PM
neatolds
Jul 12, 2015 06:41 PM
