73 Cutlass -- Blinkers only blink on left, no clicking on right.
Old Jul 22, 2020 | 06:15 AM
Tfitz's Avatar
My left blinker works perfectly. On the right, there is no "click click click" and the dash arrow stays solid, and the far right taillight goes dark unless I cancel the signal. All 4 taillight bulbs are working, so it's not a bad bulb. Would this be the turn signal switch inside the column, or the turn signal relay in the dashboard? Or possibly a bad fuse? Something else I'm not thinking of?
I'm a bit stumped that one side works perfectly and the other side doesn't. Any help appreciated.
Old Jul 22, 2020 | 08:56 AM
The tail light and the turn signals are 2 separate circuits and 2 separate filaments within the lamp. Just because the tail light works does not mean the other filament is good. Turn on the 4 ways and check the bulb that does not blink.
Old Jul 22, 2020 | 11:43 AM
You have a bulb burned out. The turn signal circuit is designed so that when a bulb burns out, it will not flash and the indicator stays on solid. Find and replace the burned out bulb.
Old Jul 22, 2020 | 05:36 PM
Tfitz's Avatar
I'll be damned if my far right bulb isn't toast. Thank you to you both--I'm new to this '73 and am learning as I go.
Old Jul 22, 2020 | 05:37 PM
Tfitz's Avatar
Thanks for the help, and hello from Tulsa!
Old Jul 22, 2020 | 07:12 PM
Your very welcome, perhaps we may run into each other at some time.
jeclin
Aug 26, 2018 10:44 AM
Alg
Apr 15, 2015 09:02 PM
Freddy B
Jul 6, 2014 08:57 AM
1BOSS83
Jun 30, 2014 11:40 AM
gabe442
Jun 9, 2012 10:07 AM
