72 taillight wire diagram
Old Mar 17, 2024 | 12:14 PM
philv1983's Avatar
I'm re wiring the taillights, I have green and brown on both sides. Which colors does what? Building the harness away from the car so can't use a test light right now to test.
Old Mar 17, 2024 | 02:13 PM
Here is a 72 wiring diagram
You have a green and brown for the right side but the left side should be yellow and brown. The brown is for the tail lights and the yellow and green are brake/turn signals.
Old Mar 17, 2024 | 08:10 PM
There is also light green for the reverse lights.
Old Mar 18, 2024 | 06:35 AM
How are you building a harness without a factory wiring diagram?
Old Mar 18, 2024 | 06:37 AM
philv1983's Avatar
both sides are green and brown. There's no yellow wire anywhere.
Old Mar 18, 2024 | 06:39 AM
That would be incorrect, or someone has mucked with it previously. The turn/brake wires to the rear lights have to be different circuits, otherwise both sides would flash when you put the turn signal on. Light green is backup lights.
Old Mar 18, 2024 | 06:40 AM
philv1983's Avatar
I'm installing led boards and there wire diagram shows a yellow wire in factory harness which mine doesn't have. Both sides are green and brown.
Old Mar 18, 2024 | 06:42 AM
philv1983's Avatar
it's all original. When I get home tonight I'll post some pics. That's why I was confused
Old Mar 18, 2024 | 06:45 AM
Apparently it isn't all original. In any case, the colors are irrelevant. What matters is that the turn/stop filaments in the LH 1157 bulbs are connected to the LH rear terminal on the turn signal switch, and the RH turn/stop filaments are connected to the RH rear terminal.
Old Mar 18, 2024 | 06:54 AM
Loaded68W34's Avatar
Excaclty which wires are you looking at? The harness in the trunk has a yellow and brown wire on the left and a green and brown wire on the right as stated above. However, the wires coming from the tail lights that plug into that harness are brown and green on both sides. The unit below is a 70, but the wiring is the same on a 71-72. Are you looking at the wires in the actual harness in the trunk, or are you looking at the wires under the car in the bumber area?
Old Mar 18, 2024 | 07:02 AM
philv1983's Avatar
both. The harness in the trunk has green, brown, light green. Absolutely no Yellow. Its original old wiring, and everything works correctly I was just confused when my directions was talking about a Yellow wire which is why I made the post. I'll add pics of the trunk harness tonight so everyone can see what I'm talking about. I know I'm not going crazy.lol
Old Mar 18, 2024 | 02:38 PM
From the factory the left turn/brake wire is yellow. If there is no yellow wire, someone in the past has made some repairs or modifications.
Has the car ever been wired for a trailer plug?
Look at the taillight harness connector near the fuse box, I bet you find a yellow wire there.
JVCCutlass
May 22, 2023 05:28 AM
Bad68442
Jan 26, 2022 05:55 PM
Phoenix8990
Jun 21, 2021 04:29 AM
Mark71
Aug 15, 2016 06:30 AM
rocketman77
Nov 11, 2013 06:40 AM
