71 cutlass horn relay question
can someone tell me what the 3 wires are that plug into the bottom of the horn relay, i believe they are black, green, and pink with a black stripe. i am trying to update some of my under hood wiring and components to modern pieces and believe that this piece could possibly be eliminated/ replaced. thanks
The factory piece is damaged and needs to be replaced I'm also in the process of doing a LS swap and updating a good portion of the under hood wiring. I have a relay block that houses 8 relays and would like to use that to keep all my relays in one location and help clean up my engine compartment. My car is far from stock so I'm not overly concerned with replacing factory parts.
JustJordy
November 9th, 2010 10:44 AM
