71 cutlass horn relay question
Old Oct 25, 2012 | 05:38 PM
Houston_t's Avatar
can someone tell me what the 3 wires are that plug into the bottom of the horn relay, i believe they are black, green, and pink with a black stripe. i am trying to update some of my under hood wiring and components to modern pieces and believe that this piece could possibly be eliminated/ replaced. thanks
Old Oct 25, 2012 | 05:50 PM
OLDSRALLYE350's Avatar
green goes to horn , the other 2 has one going to the horn button and one to the key in the ignition buzzer.
Old Oct 25, 2012 | 06:15 PM
Assuming the factory terminals are in place, the can go on the relay only one way.
Old Oct 25, 2012 | 06:54 PM
Houston_t's Avatar
The factory terminals are there just weren't sure where they lead back to, would like to remove the relay and replace it with an updated piece.
Old Oct 25, 2012 | 07:00 PM
tru-blue 442's Avatar
Old School Olds
Why?
Old Oct 25, 2012 | 07:05 PM
Houston_t's Avatar
The factory piece is damaged and needs to be replaced I'm also in the process of doing a LS swap and updating a good portion of the under hood wiring. I have a relay block that houses 8 relays and would like to use that to keep all my relays in one location and help clean up my engine compartment. My car is far from stock so I'm not overly concerned with replacing factory parts.
Old Oct 25, 2012 | 07:10 PM
Old School Olds
^^^ Good answer.
Houston_t's Avatar
pcard
May 14, 2014 01:21 PM
tcarroll
Jul 16, 2012 04:21 PM
gman
Jan 13, 2012 07:43 AM
JustJordy
Nov 9, 2010 10:44 AM
wanderalone
Oct 20, 2010 07:20 AM
