71 442 OEM Battery Question
Old Oct 8, 2021 | 07:11 AM
4-Speed's Avatar
Would anyone know the correct OEM battery part number for a 71 442 4-speed with A/C?
Also, need this battery for show
thanks
Old Oct 8, 2021 | 08:17 AM
Hairy Olds's Avatar
Shoveling Snow
R-71
Old Oct 8, 2021 | 08:30 AM
Sometimes you get lucky, sometimes you don't. Happens the 1971 PIM demonstrates the OEM battery number. Section 12, Page 150 (384)
Last edited by Vintage Chief; Oct 8, 2021 at 08:38 AM. Reason: page 150 not page 50
Old Oct 8, 2021 | 08:36 AM
Old Oct 8, 2021 | 08:45 AM
4-Speed's Avatar
You guys are great! thanks so much, really appreciate the help! Now if I can find one.....
-Dave
Old Oct 8, 2021 | 08:46 AM
Old Oct 8, 2021 | 04:58 PM
VC455's Avatar
Barely Registered
I've occasionally seen used R71 batteries, but they are rare. R71 was only used in 1971 models equipped with the 455 or optioned with the heavy duty battery. In the Toro, it was used for only part of 1971, being replaced by the R91 side terminal.
Some Delco batteries are reproduced with a modern AGM (no gassing, no corrosive vapors, far higher CCA) inside a reproduction shell.
Unfortunately for you, the R71 is not reproduced. The R71S is reproduced. It is the same size and appearance as an R71, except it says R71S in small raised letters on the sidewall.
If that doesn't bother you, you can get an R71S (eventually) from Battery Central Mall for less than you would probably pay for an original, worn-out, display-only R71.
Old Oct 8, 2021 | 05:14 PM
This one went for one pretty penny today.
NOS GM DELCO ENERGIZER R71 E-5000 BATTERY BUICK CHEVY OLDS PONTIAC
Old Oct 8, 2021 | 05:57 PM
PatL's Avatar
-Dave
not what you are looking for but a cheap alternative:
https://www.ebay.com/itm/31233728749...IAAOSwD3dekGkB
no idea if it is any good...……………..
Old Oct 8, 2021 | 07:58 PM
Hairy Olds's Avatar
Shoveling Snow
I get them in once in a while.
FStanley
Feb 28, 2023 02:48 PM
Bfg
Apr 20, 2020 07:36 AM
Hurst/Olds 73/74
Sep 25, 2016 06:26 AM
oldoldss
Mar 14, 2016 03:19 PM
72442
Jun 4, 2014 12:52 PM
