70 442 Turn Signal Wiring Harness
I tried to hook up my male turn signal wiring harness (on the column) tonight and it won't fit its female counterpart. I think the previous owner told me the column is out of a 71 or 72. My car is a 70. Should I cut both sides off and get a completely different connector or just cut off one side and find a matching half. It's so close to fitting that I might be able to modify both sides slightly and they may fit. Any advise would be appreciated.
Rick
Rick
Well my advise would be to try as much as you can to do any modifications to the column side because if you screw it up to much you would just have to replace the turn signal switch which comes with a new harness. You don't want to mess with the dash side to much cause that's a large investment it you have to replace. We just dropped almost $500 today on a having a new fuse block and harness for our 67 442. Also you may look and see if a turn signal switch for the 70 is the same up top but has the different plug. I know when I bought the one for the 67 it had an adapter that went between the column and the dash harness.
Rick
Rick
Looks like you have an aftermarket universal switch that uses a short adapter harness the fits the switch on one end and the harness on the other end. It's the connector with all black wires in the picture.
Mine came with the switch. I'm not sure if you can buy it separately. You could buy a new switch and just use the adapter harness and save the rest.
http://m.autozone.com/autozone-mobil...7x3y3?id=68394
Rick
Thanks again for the link......Rick
costpenn
June 24th, 2015 10:38 PM
