70 442 convertible top switch
Old Mar 9, 2024 | 01:57 PM
PaulWinn's Avatar
Just performed the top switch replacement job. I was really surprised how fast it went. I read several on-line posts that had me scared - I did it all through the speedo hole and left gauge hole, using a small mirror. Not at all the nightmare I expected. I think I was done in an hour. So whoever posted here the mirror method, cudos to you!
Old Feb 23, 2025 | 07:33 PM
COBRA2000's Avatar
Now i gotta do mine....
Old Mar 2, 2025 | 09:19 PM
twilightblue28A's Avatar
Same with me. I've been putting it off too. Similar reason. My car has AC. Willing to share your experience. Thank you.
Old Mar 3, 2025 | 06:43 AM
COBRA2000's Avatar
I had my mechanic do it last week.Took him about 30-mins..Did the mirror thing..Pulled both speedo and gauge cluster out.The bitch was trying to get the wires unpluged on the switch because they are locked on with snaps..He got it unplugged with two hook screw drivers and finally was able to get to the bottom screw..Then it was easy peasy from there..
Old Jul 17, 2025 | 09:25 AM
QMaster's Avatar
I just replaced mine last weekend. I've done it before so it took about 45 minutes. Of course the new switch failed almost immediately after trying it out. Switch works for putting the top down, but "up" does not work. Fusick sent me a replacement. Does anyone know of anyone that rebuilds these switches?
Old Jul 17, 2025 | 01:18 PM
Don't know anyone who rebuilds the switch. I (had to) R&R my switch on my '71 CS convertible. I purchased direct from Hyro-e-lectric. Perfect fit, high quality replacement.
NEW 1970-1972 Oldsmobile Cutlass Convertible Top Switch
Old Jul 17, 2025 | 04:33 PM
Take the switch apart and see what the contacts look like. You can probably polish them and restore functionality, but since you're taking the switch out, might as well put a new one back in instead of a worn original.
Old Jul 18, 2025 | 06:18 AM
Bee Saint Louis's Avatar
CutOvers Olds Parts Guys
Anyone tried the relay on the top switch method?
Anyone done the top switch with a relay attached? Would love to see a write up of it done. Glad you got it done and it’s working
jeclin
Nov 14, 2022 06:10 PM
smparr
Oct 19, 2020 09:52 PM
nisszx
Mar 4, 2016 11:11 PM
Redbud40
Apr 29, 2014 08:01 PM
mv213
Jan 19, 2010 08:18 PM
